had a wierd stumbling and missing every now and then
especially in low gear taking off
i have checked for the usual vac leaks plugs coil pack maf
vag com is showing 23% load at 650 rpm
sound a bit dodgy to me can anyone please confirm
the reading is high
and what it might be
no faults showing on vagcom ecu diagnostics
group 5 idle control
thanks for the reply
Monday,01,April,2013,05:20:02:04735
VCDS Version: Release 11.11.5
Data version: 20121222
Address 01: Engine (021 906 256 )
05:19:50 Group 001: General Engine Data
680 /min RPM
88.5°C Coolant Temperature
0.0 % Lambda
5.3 °BTDC Ignition Angle
05:19:50 Group 005: Idle Control
680 /min RPM
20.7 % Engine Load THIS IS THE ONE
0.0 km/h Road Speed
Idle Operating Mode
05:19:50 Group 006: Fuel Trim
680 /min RPM
0.21 g/s Idling Air Mass Learnt Value
74.5 % Throttle VPOS Duty Cycle Lval.
01 0 AC Compressor Status
Going off the VAG measured value blocks rather than vagcom ones engine load should be MVB 3 Zone 2 and should be between 1 & 4%
Display group 3 -Basic functions- for control unit number: 021906258A ... CK
Read measured value block 3
[ltrif ] Indicated on display
xxxx rpm
x.xx %
xx <°
xxx.x °C
1
2
3
4
[ltrif ] Display zones
Specification
Evaluation
Intake air temperature
-45...108.5 °C
Throttle valve angle
9...19 <°
Engine load
1.0...4.0 %
Engine speed (idling speed)
650...750 rpm
Hope that makes a bit of sense, was everything switched off i.e lights, heater, and any other electrical consumers?
