binliner 0 Posted April 4, 2005 Report Share Posted April 4, 2005 I need some spacers for my rear wheels... not sure yet whether to get 10mm or 15mm (per side) but what are the best ones to get?Gwent VW recommend for 10mm using standard drilled spacers with longer bolts and for 15mm they do ones that bolt to your hub which you then bolt the wheel to using your existing bolts (I take it this is hubcentric?) both are FK... does this sound right?anyone got any recommendations/advice? Link to post Share on other sites
Eat this 2 Posted April 4, 2005 Report Share Posted April 4, 2005 id put the smallest u can get away with as it puts more stress on the wheel bearings Link to post Share on other sites
acf8181 0 Posted April 4, 2005 Report Share Posted April 4, 2005 you can get spacers for stub axles apparantely....much much lighter on your wheel bearings. worth a thought perhaps.[ Edited Mon Apr 04 2005, 08:04PM ] Link to post Share on other sites
binliner 0 Posted April 4, 2005 Author Report Share Posted April 4, 2005 what are they then? Link to post Share on other sites
Eat this 2 Posted April 4, 2005 Report Share Posted April 4, 2005 you can get spacers for stub axles apparantely....much much lighter on your wheel bearings. worth a thought perhaps.do they move the actual hub a bit andrew?? Link to post Share on other sites
mk3anni 0 Posted April 4, 2005 Report Share Posted April 4, 2005 you can get spacers for stub axles apparantely....much much lighter on your wheel bearings. worth a thought perhaps.is that much use on a car with 4 wheel drive?????? Link to post Share on other sites
VR6Steve 0 Posted April 8, 2005 Report Share Posted April 8, 2005 Justin - have you thought of asking David H about what he can supply via Tunershop? Link to post Share on other sites
binliner 0 Posted April 8, 2005 Author Report Share Posted April 8, 2005 yep have spoken to David since posting this Link to post Share on other sites
