Dirtysanchez 0 Posted July 19, 2012 Report Share Posted July 19, 2012 Hi all,I noticed the other day that the handbrake warning light was very dimly lit whilst I was driving along. It would occasionally flicker brightly if I hit a bump in the road etc. The following day I changed the brake fluid, thinking it might be warning me of low fluid. So it's now got nice, new, fresh fluid. This hasn't cured the light though. Could the light be a low pad warning? I did the fluid with the wheels on, so didn't really look at the discs and pads (also, I seem to remember that they were changed not long before I bought it in May/June).P.S - I know I should probably have checked/changed the discs and pads before the fluid, but I was being lazy Link to post Share on other sites
cabrioman 6 Posted July 19, 2012 Report Share Posted July 19, 2012 do you mean the hand brake light ??? if so if the fluid is ok its either the hand brake switch or the sensor on the brake fluid Link to post Share on other sites
kentyboy 0 Posted July 19, 2012 Report Share Posted July 19, 2012 does the abs light come on and go off? as i had this problem when i had a problem with my abs.....turns out it was a bad connection to the abs bulb,for some reason it puts the handbrake light on...or makes it flicker... Link to post Share on other sites
cabrioman 6 Posted July 19, 2012 Report Share Posted July 19, 2012 the abs lights puts the handbrake light on as an extra visual warning, Link to post Share on other sites
Dirtysanchez 0 Posted July 19, 2012 Author Report Share Posted July 19, 2012 Yeah the ABS is fine I've had a quick look on Google and most people seem to suggest (like Tony) that it's either the handbrake switch or fluid sensor, so I'll have a look at both this weekend Link to post Share on other sites
Lukey. 381 Posted July 20, 2012 Report Share Posted July 20, 2012 Yea I bet it's the switch on the handbrake Link to post Share on other sites
Mk3highline 287 Posted November 7, 2014 Report Share Posted November 7, 2014 I got same problem but comes on with the fan heater fan or the lightsI think it's a bad earth but where engine side are good as checked when did engine swap Where are the earths in the cabin? Link to post Share on other sites
Mk3highline 287 Posted November 26, 2014 Report Share Posted November 26, 2014 Fixed it finally it was a bad Earth on the engine loom changed them and earthed throttle body as its on the 24v inlet and its sorted plus added another earth from bat to body and engine to bat Link to post Share on other sites
