you've got the lower manifold off?? or upper?
the fuel rail has 2 bolts at the top and 2 at the bottom and the injectors are held into the fuel rail and the lower manifold by the rubber o rings... they're basically just a very tight fit and usually require a good bit of twisting and pulling to get them out!
