please help any ideas? dont wanna drive car if somethings wrong. noise goes when i spray the belt but cant do that forever.
belt is conti-tech £35 job and is aligned properly , i cleaned all the pulleys and all are fine - no play.- hard to hear bearing from spinnin by hand
prob nothing to do with it but i changed water pump after the fins on old one disintegrated however couldnt get all the broken fins out of cooling system.
your right just changed it should work
Get a long flat head screw driver.
Place it on the Belt Tensioner.
Place your ear on handle of screwdriver and listen.
Dont forget to rev the car with other hand via Throttle!.
Maybe the bearings in the Tensioner itself.
noise was after first fitting belt but went after i sprayed it before coming back. i sprayed it again and so far it appears to have gone after driving it today, but its weird that to stop it squealing initially i had to spray it?
i bought it from eurocarparts ,expensive belt but really not sure if its the type that has to settle??
i have listened to everythin with screwdriver and seems quite.
will update after drivin it for a while to whether noise comes back or not.
cheers guys
if it goes when you spray the belt id be inclined to say its the belt ..... just because its an expensive belt don`t mean its a good belt if you know what i mean, try buying a cheap one see how that goes or if its still does it .....
i bought a cheapy to start and it was really noisy , yeah i know what your saying will see if this one wears in atall , today seemed normal, a frustrating problem i just hope it settles in as i had no trouble with the old belt on the car that was hugely cracked
found the prob. pulley was straight on power steering pump however at low revs you could visually see the pulley moving about -even though i had checked the pulley for play.
so i thought if the noise goes at higher revs it might be the centrifugal force straightening it and the reason it comes back at low revs is cause there isnt enough force there to keep it straight, making it move about?
anyway second hand pump it is , cheers for the help.
in the mean time is it ok to use the car with the bad pump untill pump comes ?
