paceo 22 Posted November 22, 2011 Report Share Posted November 22, 2011 on the golf vr6 i had a leak from the oil filter hosuing so i replaced the oil filter seal and it still leaked? i believe the leak is coming from the 2x sensors above this? are they common problem to leak?what sensors are they and who supplies them?? :-) Link to post Share on other sites
VR6Pete 1,455 Posted November 22, 2011 Report Share Posted November 22, 2011 sure its not coming from your oil cooler, directly above your oil filter housing... Link to post Share on other sites
hoppinmad 0 Posted November 22, 2011 Report Share Posted November 22, 2011 i had a leak from the sensors(oil pressure switch`s blue & black) pretty straight foward inexpensive to sort, common fault. got mine from my local vag spare centre cost £10.99 for both Link to post Share on other sites
Pearsy47 1 Posted November 22, 2011 Report Share Posted November 22, 2011 i have a spare oil filter housing wit the two sensors in it if you want it let me know ! Link to post Share on other sites
paceo 22 Posted November 22, 2011 Author Report Share Posted November 22, 2011 sure its not coming from your oil cooler' date=' directly above your oil filter housing...[/quote']nope done the oil cooler seals about 3 months ago! the 2 sensors above the oil filter housing are a little wet with oilanyone got a part number for them? Link to post Share on other sites
Pearsy47 1 Posted November 22, 2011 Report Share Posted November 22, 2011 i have a spare one or do you want just the sensors ?? Link to post Share on other sites
hoppinmad 0 Posted November 22, 2011 Report Share Posted November 22, 2011 028 919 081 H blue sensor068 919 081 D black sensor Link to post Share on other sites
Andi 0 Posted November 22, 2011 Report Share Posted November 22, 2011 Is the oil comming out of the actual sensor ? Or can you just replace the copper washers ? Link to post Share on other sites
paceo 22 Posted November 22, 2011 Author Report Share Posted November 22, 2011 Is the oil comming out of the actual sensor ? Or can you just replace the copper washers ?just where the washer sits :-) Link to post Share on other sites
Caddyslammed 16 Posted November 22, 2011 Report Share Posted November 22, 2011 I had had a couple of leaks before on theses sensors, both leaked from the top, at the spade connector. Link to post Share on other sites
hoppinmad 0 Posted November 22, 2011 Report Share Posted November 22, 2011 I had had a couple of leaks before on theses sensors' date=' both leaked from the top, at the spade connector.[/quote']exactly where mine leaked from. pull off the black rubber cap on the sensor and if oil comes out then its leaking at the top Link to post Share on other sites
paceo 22 Posted November 22, 2011 Author Report Share Posted November 22, 2011 well i left the engine running and you can see the oil seeping out of the big sensor on the left, what size is it? looks like a 23 or 24mm and doesnt look like ill get my spanners in there! Link to post Share on other sites
hoppinmad 0 Posted November 22, 2011 Report Share Posted November 22, 2011 i think its a 23mm, i used several extension bars and a U.J. and a good bit of wiggling, do with a cold engine because you will have to wedge a limb down the gap Link to post Share on other sites
paceo 22 Posted November 23, 2011 Author Report Share Posted November 23, 2011 thanks guys is there any VW dealers that will deliver? nearest garage is a mission away!well looked on vag cat, and there is a seal part number, it looks like its just leaking from the seal? Link to post Share on other sites
paceo 22 Posted November 28, 2011 Author Report Share Posted November 28, 2011 got the sensors guys, they look like a bastard to get to! possible 23mm i think??just a quick one there is black and blue, which side do they sit on?? Link to post Share on other sites
paceo 22 Posted November 29, 2011 Author Report Share Posted November 29, 2011 black and blue what side do they go on guys? Link to post Share on other sites
