rsweeney 40 Posted November 14, 2011 Report Share Posted November 14, 2011 how do you bleed this properly as i have just replaced it? Link to post Share on other sites
cbmotorsport 0 Posted November 14, 2011 Report Share Posted November 14, 2011 fill the resevoir up, have a friend pump the pedal lots of times, get them to hold it down whilst you open the bleed nipple, close it back up, have them keep pumping a few times, hold it down, undo bleed niple and repeat until clutch pedal feels good Link to post Share on other sites
rsweeney 40 Posted November 14, 2011 Author Report Share Posted November 14, 2011 thanks do i need an easy bleed kit or just a tube and bottle ? Link to post Share on other sites
bungy 2 Posted November 14, 2011 Report Share Posted November 14, 2011 thanks do i need an easy bleed kit or just a tube and bottle ? Depends on if you are doing it on your own or not. If you can get a helper then no need. Link to post Share on other sites
cbmotorsport 0 Posted November 14, 2011 Report Share Posted November 14, 2011 as bungy said, if youve got a friend, then just use pipe and a bottle so you dont make a mess. from experience, those easy bleed kits are a PITA for doing clutches Link to post Share on other sites
p0u1 14 Posted November 16, 2011 Report Share Posted November 16, 2011 i used a bleed kit and i cant have anything bad to say about it, made the job easy and i had no problems with the clutch.oh i went off my tire that wasn't at the recommended pressure lol as the pump source probs about 33psi not 15psi or whatever they tell you is t5he maximum pressure the kit can take and i had a nice long bit of tube to put over the blead nipple into a old milk bottle it was rather tidy and didn't need to worried about the person pumping the pedal at the wrong time and getting air in the system. Link to post Share on other sites
rsweeney 40 Posted November 16, 2011 Author Report Share Posted November 16, 2011 will try it with a mate this weekend and see, do you do it with it bolted onto gearbox ? Link to post Share on other sites
