V1 supercharger belt.
Before i take the front off of my car to measure with string the belt length i need minus the aircon pump as my doesnt have aircon, currently though has an aircon pump in place as the only belt we could get was a long one, does anyone know what sort of length belt i might need without aircon?,not sure which size pulley is on the charger though.
thanks
Ok after doing some research on belt sizes form the link that caddyslammed posted up ive found the following.
Vortex forum suggest that the belt maybe 53.5" long for a non aircon belt for a Supercharger.
After calling a friend that is the exact same length as a Standard aircon belt without the charger (1360mm).
So im just trying to back this up with a little more evidence.
1 Belt
w/o A/C pulley This p/n breaks down as 080 - 8rib belt, 570 - 57" length.
This particular belt is for a car with no AC and a smaller pulley. This series of belts should be available in a range of lengths, just order 25-080*** and fill in the desired length. One rib must be cut off to make this a 7 rib belt.
w/ A/C pulley 7 rib - 61.5" long
taken from here guys http://www.venommotorsports.com/library/VortechSC.asp
