paceo 22 Posted October 12, 2011 Report Share Posted October 12, 2011 battery light is on the vr6 now and i have to charge the battery every 5 days or so, before i whip the alternator off is there anything else that can stop the battery from charging like dodgy earths, if so where are the earths for this? regards :-) Link to post Share on other sites
legvw 0 Posted October 12, 2011 Report Share Posted October 12, 2011 Check the output of the alternator, should be around 14v when running. Link to post Share on other sites
spadam 7 Posted October 12, 2011 Report Share Posted October 12, 2011 There is an earth under the battery tray worth checking. Think there is also one on the block, just follow the earth lead from the alternator. Link to post Share on other sites
paceo 22 Posted October 13, 2011 Author Report Share Posted October 13, 2011 There is an earth under the battery tray worth checking. Think there is also one on the block' date=' just follow the earth lead from the alternator.[/quote']cheers mate there is one in front of the battery tray by the washer bottle, and the black lead from the alternator attatches to the starter motor then onto the positive terminal. negative terminal goes into some block???? under the header tank and again onto the starter motor. cleaned everything and still battery light is on. Link to post Share on other sites
bungy 2 Posted October 13, 2011 Report Share Posted October 13, 2011 What voltage is your alternator putting out? Link to post Share on other sites
paceo 22 Posted October 13, 2011 Author Report Share Posted October 13, 2011 What voltage is your alternator putting out?11.93 when the car was running, it should be 14. Link to post Share on other sites
bungy 2 Posted October 13, 2011 Report Share Posted October 13, 2011 Sounds like you do need an alternator then. Link to post Share on other sites
paceo 22 Posted October 14, 2011 Author Report Share Posted October 14, 2011 cool will this one on ebay do the job?? even though mines a 1992 car and this says 1995-1997?also mines a 70 and not a 90!http://www.ebay.co.uk/itm/ALTERNATOR-VW-Golf-III-2-8-VR6-95-97-/370537242489?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5645bd9f79:-) Link to post Share on other sites
paceo 22 Posted October 14, 2011 Author Report Share Posted October 14, 2011 ?? Link to post Share on other sites
VDub_Steve 1 Posted October 14, 2011 Report Share Posted October 14, 2011 That ones fine mate Link to post Share on other sites
paceo 22 Posted October 16, 2011 Author Report Share Posted October 16, 2011 That ones fine matecool only thing is the electrical plug in connector looks different to mine??? Link to post Share on other sites
VDub_Steve 1 Posted October 16, 2011 Report Share Posted October 16, 2011 It should be the same mate tbh Link to post Share on other sites
The Monk 50 Posted October 16, 2011 Report Share Posted October 16, 2011 11.93v, to me, means that your battery is not being charged buddy.Had the same on my passat and it sat at 11.93 for ages....untl I went for a drive wth music blasting and had no juice.If you're buying off the bay, make sure you give your cars build year and/or engine code.They should have the year of car/engine that the alternator fits or replaces.90A instead of 70A is fine.Look for the alternator for your car... 91 - 94 ect. Link to post Share on other sites
paceo 22 Posted October 16, 2011 Author Report Share Posted October 16, 2011 It should be the same mate tbhi did think the alternators are the same throughout the range of vr6? Link to post Share on other sites
VDub_Steve 1 Posted October 16, 2011 Report Share Posted October 16, 2011 It should be the same mate tbhi did think the alternators are the same throughout the range of vr6?I got one from a vr6 people carrier and was fine Link to post Share on other sites
paceo 22 Posted October 17, 2011 Author Report Share Posted October 17, 2011 this is what i mean look at the difference between the terminals on the 70amp and 90amp Link to post Share on other sites
jims13 6 Posted October 17, 2011 Report Share Posted October 17, 2011 should have said in the pm ,that was for a 90 amp unit , assuming you had aircon ..my supplier can no longer get the 70amp units. its possible the 90 amp ones have superseded the old ones, connections may be different sue to diff makes, i.e , valeo, bosch , lucas .. Link to post Share on other sites
