Knightrider 1 Posted August 9, 2011 Report Share Posted August 9, 2011 Sorry folks, probably a pathetic question. Just got a used BMC CDA85-150 from the Corrado Forum. Have fitted it and it sounds like the doggies doodaas, awesome. shagged my fuel consumption!! Used a 9 inch flower pot to wedge it into a controlled position (so I could use/listen to it), Clearly only a temp arrangement. Sooooo.....Where is the best place/bolt to attach it to stabilse it - onto an engine bolt - one of the serpentine tensioner bolts maybe? Or to a bolt on the body....if so which one? Which bolt. Where? N Link to post Share on other sites
cabrioman 6 Posted August 9, 2011 Report Share Posted August 9, 2011 normally to the belt tensioner mate with some flat bar with holes in it .... Link to post Share on other sites
shail 0 Posted August 9, 2011 Report Share Posted August 9, 2011 As above. Put a 90 degree bend in the bar. Attach one side to tensioner other to the CDA Link to post Share on other sites
Knightrider 1 Posted August 10, 2011 Author Report Share Posted August 10, 2011 Thanks people, much appreciated. Found that you don't need to put a 90 degree bend in it....and the holes in the retaining bracket SPF200K are too small for the tensioner bolt, needs drilling out. Link to post Share on other sites
Knightrider 1 Posted August 10, 2011 Author Report Share Posted August 10, 2011 They sound soooo good!!!! Link to post Share on other sites
