AEM AFR sensor location
Thanks Tony, I am just researching at the moment. I have got the 6 branches with no exhaust wrap on them, and I have cat back on. So I just wanted to know the best location. I was thinking about putting the sensor at the bottom of 6 branches? Unless you had some magic trick where u placed yours before?
The stock cat has a lambda socket in it, which is where I would put it personally. You may need to check the lamdba socket can take wideband though because narrowbands have smaller diameter tips.
You will see what I mean when you try and screw a wideband probe into a narrowband hole!
Good choice of wideband kit. I like that AEM setup very much.
