leigh_f 0 Posted June 29, 2011 Report Share Posted June 29, 2011 himy vr6 golf obd2 has developed a fault. upon closer inspection i found that there is no spark to cylinder 2, changed leads and still nothing. the lead isn;t even arching so problem is before lead. i have repaired coil pack in the past with the jb weld method and can;t see any cracking. is there anything else to consider or test before shelling out for a brand new coil pack??thanks Link to post Share on other sites
Daverse 175 Posted June 29, 2011 Report Share Posted June 29, 2011 Chang the HT lead for one that you know is firong properly, there may be a crack in the wire or something. if not, probably your coil pack mate Link to post Share on other sites
leigh_f 0 Posted June 29, 2011 Author Report Share Posted June 29, 2011 done that same cylinder missing. leads are fresh out of pack an hour ago! Link to post Share on other sites
leigh_f 0 Posted June 29, 2011 Author Report Share Posted June 29, 2011 thanks for suggesting it though Link to post Share on other sites
VR6Pete 1,455 Posted June 29, 2011 Report Share Posted June 29, 2011 try swapping a spark plug around, if you have same sympton, then id say its your coilpack Link to post Share on other sites
leigh_f 0 Posted June 29, 2011 Author Report Share Posted June 29, 2011 if it was plug would i still get arch from lead? if not i will swap plug aroundthanks Link to post Share on other sites
Dave Lea 4 Posted June 29, 2011 Report Share Posted June 29, 2011 Deffo the coil fella Link to post Share on other sites
p0u1 14 Posted July 1, 2011 Report Share Posted July 1, 2011 the coil pack normaly takes out two cylinders if the coilpack gos wrong, if you got a spare coi pack try thats, if you got one with bad coils just change the imc (i maybe wrong with the name) but its the part on the side of the pack with 4 forks coming off it, mine went wrong and i lost two cylinders Link to post Share on other sites
leigh_f 0 Posted July 2, 2011 Author Report Share Posted July 2, 2011 thanks guys just trying to get a new pack without paying silly money! Link to post Share on other sites
