rsweeney 40 Posted March 30, 2011 Report Share Posted March 30, 2011 how do i get the driveshaft boot all the way on im really stuck now cannot seem to get the damn thing on, it is so tight how do i get this on ? Link to post Share on other sites
b road blaster 0 Posted March 30, 2011 Report Share Posted March 30, 2011 i put a small skrewdriver into the boot then worked it round as i pulled it on but was bloody tight also used very small amount of washing up liquid to help it slide Link to post Share on other sites
rsweeney 40 Posted March 30, 2011 Author Report Share Posted March 30, 2011 ok thanks will try that, did you do it whilst gearbox was in car etc? and which end of the boot did you stick the screw driver into from? Link to post Share on other sites
b road blaster 0 Posted March 30, 2011 Report Share Posted March 30, 2011 yep in car just used a very small electical one from the fat (g/box) end and just made sure it was blunt so not to puncture the boot and worked it around whilst pulling like a bitch Link to post Share on other sites
pfennell 0 Posted March 30, 2011 Report Share Posted March 30, 2011 ah i done the same yer whilst the g/b was fitted it took around 4 hours of swearing,sweat and tear i through my teddy all over i think i finished around 1 in the morning after which i thought it would take 30 mins top....good luck mate Link to post Share on other sites
rsweeney 40 Posted March 30, 2011 Author Report Share Posted March 30, 2011 flip, 4 hours ! thanks guys will start sat morning and see what happens. will need to find blunt screw driver or something in the mean time Link to post Share on other sites
b road blaster 0 Posted March 30, 2011 Report Share Posted March 30, 2011 don't need to be a skrewdriver just somthing small that the boot will slide up mate and just keep working it around mine took less than 15 min then filled it with the greese from small end and done the clip up tight Link to post Share on other sites
rsweeney 40 Posted March 30, 2011 Author Report Share Posted March 30, 2011 ok cheers, you used a clip?what sort ? Link to post Share on other sites
b road blaster 0 Posted March 30, 2011 Report Share Posted March 30, 2011 well my kit came with them the proper factory type ones that you pull up like a wire tie then crimp up but i would have thought a wire tie would hold it mate Link to post Share on other sites
rsweeney 40 Posted March 30, 2011 Author Report Share Posted March 30, 2011 ok where can i buy these from as most shops ive looked in dont have them and said just use plastic cable ties Link to post Share on other sites
b road blaster 0 Posted March 30, 2011 Report Share Posted March 30, 2011 not sure over there mate as said mine came with the boot as a kit Link to post Share on other sites
