Where does this go???
yep, there will be a moulded bump in the carpet near the front mount of the seat, prod it and it will be a hollow hole, that goes underneath it to fill the space and the 2 prongs pop into 2 holes in the floor to properly locate it, seat out and doorway floor trim off and you should be able to lift the carpet enough to re locate it, although if theyve been buggering about with all that under the seat you may want to have a better look and check that they put the under seat vent back properly if they took that out too.
