craggsy 91 Posted February 2, 2011 Report Share Posted February 2, 2011 I had schrick off for a bit and I could feel the difference even with the charger Link to post Share on other sites
chief ka kar 0 Posted February 2, 2011 Author Report Share Posted February 2, 2011 At the moment it would have to be one or the other. Which one would you go with ? Link to post Share on other sites
craggsy 91 Posted February 2, 2011 Report Share Posted February 2, 2011 Charger......without a doubt Link to post Share on other sites
chief ka kar 0 Posted February 2, 2011 Author Report Share Posted February 2, 2011 Cheers for that, would a stage1 charger be ok without putting a spacer plate in. Link to post Share on other sites
chief ka kar 0 Posted February 3, 2011 Author Report Share Posted February 3, 2011 Just doing some more read up on chargers, will i need to upgrade my fuel pump as well. Just wanted to get a full cost together. Link to post Share on other sites
FishWick 21 Posted February 3, 2011 Report Share Posted February 3, 2011 Stock Corrado 4 bar pump (yours is 3 bar being OBD2) can hold 8psi of Stage 2 Vortech, just.If you're going Rotrex, I would defo fit an uprated pump. Walbro GSS340. Stealth Racing sell them and also supply the required sleeve for a snug fit into your pump housing. Approx £100. Link to post Share on other sites
spadam 7 Posted February 3, 2011 Report Share Posted February 3, 2011 Kev if you upgrade the fuel pump itself do you also need to upgrade the fuel pressure regulator on the fuel rail. Not to clued up on that. As i wanting to get a rotrex but no i need to upgrade the fueling system to unsure reliability. Link to post Share on other sites
FishWick 21 Posted February 4, 2011 Report Share Posted February 4, 2011 Not always mate, it depends on the mapping and injector sizing etc.All a regulator does is set the chosen rail pressure and then throws the surplass back to the tank. It's not a good idea to run a 4 bar reg with a 3 bar pump, but a 4 bar pump with a 3 bar reg is fine. Always over pump to regulator!The important bit is making sure the pump can sustain the required flow in boost because as fuel pressure increases, flow reduces.So if you had your 3 bar pump running a 4 bar regulator, already at wide open throttle the the reg is demanding 4 bar, 1 bar over the pump's specification. Then add a bar of boost on top of that, it's got to deliver 5 bar pressure.If you had the 4 bar pump, it would only be 1 bar over pressure, which some pumps are OK with, but not the stock VW ones.It's why the Bosch 044 is so good. It can run at 8 bar with good flow to match! :-) Link to post Share on other sites
spadam 7 Posted February 4, 2011 Report Share Posted February 4, 2011 Looks like i will leave my Fuel regulator along and buy a Bosh 044 fuel pump. Will prob have to get some larger injectors as im wanting to run 8psi with a rotrex hopefully just under the 300bhp mark. Link to post Share on other sites
spadam 7 Posted February 4, 2011 Report Share Posted February 4, 2011 Sorry think rotrex is 10psi Link to post Share on other sites
chief ka kar 0 Posted February 4, 2011 Author Report Share Posted February 4, 2011 I already have the 4 bar reg better leave that till i get the uprated pump in cheers for the info Link to post Share on other sites
chief ka kar 0 Posted February 4, 2011 Author Report Share Posted February 4, 2011 Thinking about this alot, i think i may start at the base before charging ie new clutch, new chains and put spacer in. Would the spacer plate make any differance to a stock engine ??? Link to post Share on other sites
FishWick 21 Posted February 4, 2011 Report Share Posted February 4, 2011 Looks like i will leave my Fuel regulator along and buy a Bosh 044 fuel pump. Will prob have to get some larger injectors as im wanting to run 8psi with a rotrex hopefully just under the 300bhp mark.Sorry mate, I should have added that you don't really need an 044 unless you're exceeding 400-450hp or are having fuelling shortages at the top end, assuming it's not injector related.The 044 is a horribly noisy pump and is external, so needs all the external fitting parts to go with it. If you're going for 10psi, the Walbro in-tank pump Stealth sell is more than up to the job! Link to post Share on other sites
FishWick 21 Posted February 4, 2011 Report Share Posted February 4, 2011 Thinking about this alot' date=' i think i may start at the base before charging ie new clutch, new chains and put spacer in. Would the spacer plate make any differance to a stock engine ???[/quote']You mean drive it around as low compression before putting the charger on? Won't make a huge difference to be honest, slightly worse throttle response. Link to post Share on other sites
spadam 7 Posted February 4, 2011 Report Share Posted February 4, 2011 Looks like i will leave my Fuel regulator along and buy a Bosh 044 fuel pump. Will prob have to get some larger injectors as im wanting to run 8psi with a rotrex hopefully just under the 300bhp mark.Sorry mate' date=' I should have added that you don't really need an 044 unless you're exceeding 400-450hp or are having fuelling shortages at the top end, assuming it's not injector related.The 044 is a horribly noisy pump and is external, so needs all the external fitting parts to go with it. If you're going for 10psi, the Walbro in-tank pump Stealth sell is more than up to the job![/quote']Ah i see no worries so a walbro pump and by the looks of other threads red top injectors. Gota find a good supplier for red top injectors now then. Link to post Share on other sites
chief ka kar 0 Posted February 4, 2011 Author Report Share Posted February 4, 2011 Thinking about this alot' date=' i think i may start at the base before charging ie new clutch, new chains and put spacer in. Would the spacer plate make any differance to a stock engine ???[/quote']You mean drive it around as low compression before putting the charger on? Won't make a huge difference to be honest, slightly worse throttle response.Yeah i was going to get the work done in 2 stages like the new clutch chains then have the spacer put in while that work was being done. Then get the charger done at a later stage. Just wasnt sure putting a spacer in was good on stock without a charger or turbo.Or should i just wait till i can get it all done at once. Link to post Share on other sites
FishWick 21 Posted February 7, 2011 Report Share Posted February 7, 2011 Makes no odds really mate. It will prefer 95 unleaded as a low comp engine :-) Link to post Share on other sites
chief ka kar 0 Posted February 8, 2011 Author Report Share Posted February 8, 2011 Ok cheers mate, for all the info Link to post Share on other sites
