rsweeney 40 Posted January 15, 2011 Report Share Posted January 15, 2011 trouble last month as gearbox was taken out and huge split in side .. sourced replacement exactly same code payed £130 and £220 for shipping and discover this .. so pissed off now .mine was on 62,000 and this is at 50,000 so im guessing it will get worse ? Link to post Share on other sites
legvw 0 Posted January 15, 2011 Report Share Posted January 15, 2011 I've heard that auto boxes aren't that reliable, maybe for this reason. It maybe a design fault which i'm not sure you could over-come. Link to post Share on other sites
rsweeney 40 Posted January 15, 2011 Author Report Share Posted January 15, 2011 its such a shame after the trouble i went to with transport etc and the money i spent. he said it was tested twice whilst on the car as it wasnt a right off and it worked fine including going up inclines. what do i do ? I was pretty lucky to find one with the same code wasnt i ? Link to post Share on other sites
legvw 0 Posted January 15, 2011 Report Share Posted January 15, 2011 Does it leak oil through what looks like the crack?If not then use it, what have you got too loose? Link to post Share on other sites
rsweeney 40 Posted January 15, 2011 Author Report Share Posted January 15, 2011 im doing the timing chains atm so havent tested it but the old one didnt it just leaked between engine and gearbox. and yeah thats a good way to look at it i suppose Link to post Share on other sites
b road blaster 0 Posted January 15, 2011 Report Share Posted January 15, 2011 can you not get a weld run along the crack to "beef" it up a bit Link to post Share on other sites
bungy 2 Posted January 15, 2011 Report Share Posted January 15, 2011 That is amazing really as both cracks line up and are even crooked in the same places. Link to post Share on other sites
UnitedMotorsport 55 Posted January 15, 2011 Report Share Posted January 15, 2011 Both are from crash damaged cars. Link to post Share on other sites
rsweeney 40 Posted January 16, 2011 Author Report Share Posted January 16, 2011 b road blaster can you not get a weld run along the crack to "beef" it up a bit im not sure ,wouldnt heat be an issue for internal components? UnitedMotorsport Posted: Both are from crash damaged cars. how can you tell? i know that the original gearbox was involved in a small crash were someone went side on into the passengers front wing but i dont know about the replacement gearbox Link to post Share on other sites
b road blaster 0 Posted January 17, 2011 Report Share Posted January 17, 2011 well it looks like your first box has had some done on it allready i really can't see it being a prob if it was done in small sections so it did'nt get cooked in one go gotta be worth asking some pro welders Link to post Share on other sites
rsweeney 40 Posted January 17, 2011 Author Report Share Posted January 17, 2011 found this in the gearbox sump - (the new gearbox i bought ) they are very thin not sure what they are please help ? could it be a gasket or what is it? and yeah for the crack it might be worth getting a pro welder to have a look if what i found in sump isnt too serious Link to post Share on other sites
b road blaster 0 Posted January 17, 2011 Report Share Posted January 17, 2011 ok not sure but look like some bits of the clutch bands to me Link to post Share on other sites
bungy 2 Posted January 17, 2011 Report Share Posted January 17, 2011 Not sure about the debris you've found, is it metallic and is it very hard or soft?Personally I woulddn't use it with the crack and debris.Both look like they've suffered impact damage which has stressed them along the same weak point. Link to post Share on other sites
rsweeney 40 Posted January 17, 2011 Author Report Share Posted January 17, 2011 its not metalic, its relativly hard but brittle fibre material about 1mm thick and breaks under pressure of a pencil point. what should i do as a new casing is £600 and the parts inside might need replacing. the gearbox is very rare though and cant be referbed as its cracked Link to post Share on other sites
bungy 2 Posted January 17, 2011 Report Share Posted January 17, 2011 The best method for any weld repair s to use the same sort of material and in this cercumstance you have a spare gearbox to cut up for use. TIG welding along a "V" notched into the crack with the other gearbox material should sort it but I don't know what the debris is. Link to post Share on other sites
rsweeney 40 Posted January 17, 2011 Author Report Share Posted January 17, 2011 ok im not an experienced welder so might have to get a professional to do it and cut up one gearbox ,untill i know what the debris is a cant make a start because i dont know which box to use. first box has a crack and was getting stuck in one gear after a few hours, id turn it off then on and it would be ok for 10 mins then happen again. second box has debris and a crack... Link to post Share on other sites
b road blaster 0 Posted January 17, 2011 Report Share Posted January 17, 2011 if its not metal then i would say it is the clutch bands broken up so the box would need a rebuild i know a place in portsmouth the does them but not over in guernsey Link to post Share on other sites
rsweeney 40 Posted January 17, 2011 Author Report Share Posted January 17, 2011 ahh not good, what are the clutch bands ? Link to post Share on other sites
b road blaster 0 Posted January 17, 2011 Report Share Posted January 17, 2011 they are what it says on the tin lol lol when the box changes gear they work the same as a manual clutch would, they disengage and reingage the gears as you need them Link to post Share on other sites
b road blaster 0 Posted January 17, 2011 Report Share Posted January 17, 2011 http://www.jimjenningstransmissions.com/ask.asp?faq=535 Link to post Share on other sites
rsweeney 40 Posted January 17, 2011 Author Report Share Posted January 17, 2011 ok, rebuild is going to be mega money anyway id be able to rebuild it my self, what specialized tools would i need ? Link to post Share on other sites
b road blaster 0 Posted January 17, 2011 Report Share Posted January 17, 2011 not got a clue mate sorry would not know even where to start doing one never had a auto box in my life Link to post Share on other sites
rsweeney 40 Posted January 17, 2011 Author Report Share Posted January 17, 2011 i meant to say would i be able to rebuild it myself ? lol not that confident. thanks for the help Link to post Share on other sites
b road blaster 0 Posted January 17, 2011 Report Share Posted January 17, 2011 well tbh i really can't see why you could'nt do it as you have 2 box's so you could use one for refrance as you done the second one ......but i for one would not be brave enough to do it lol lol lol Link to post Share on other sites
rsweeney 40 Posted January 17, 2011 Author Report Share Posted January 17, 2011 yeah, if i tested this one incase its not one of the clutch bands will i do any damage? i do have a long parts list before the car can go back together though Link to post Share on other sites
