Neuspeed low temp thermostat
Is this the 70 deg opening one? Be careful. 70 deg is the point in the Engine map where lambda control takes over from the warm up maps. All these early opening stats do is prolong the warmup map, costing you more in fuel and running over rich. It's why VW use an 80 deg thermostat.
If the cooling system is in good health, there is absolutely no need for a lower temp stat what so ever. If the engine is over heating, look elsewhere for problems :-)
Is this the 70 deg opening one? Be careful. 70 deg is the point in the Engine map where lambda control takes over from the warm up maps. All these early opening stats do is prolong the warmup map' date=' costing you more in fuel and running over rich. It's why VW use an 80 deg thermostat.
Yes, this is what I have heard from reading a few forums, is that it uses more fuel than it needs too :)
