Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 yeah you replace the whole plastic housing mate - and they are quite expensive from memory I am afraid to say Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 the GSF ones are £56 + vat but not sure if they are much cop - maybe someone else on here who has bought one can advise ? Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 after reading on edition, obd1 VRs cut out with maf unplugged however obd2 run wiht wiht it disconnect and could mean its not the maf? someone on edition on an old thread suggest crank sensor for a similar problem? Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 as Bungy said earlier mate if you disconnect the MAF and it runs normally then its your MAF if you disconnect and it still runs like a bag of spanners then its something else ! could be a few things tbh but with those symptoms thats the first thing to check Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 Thanks alot guys really do appreciate it. ill report back tomorrow after cleaning it!cheers Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 good luck with it mate Link to post Share on other sites
bungy 2 Posted January 14, 2011 Report Share Posted January 14, 2011 If it has cured it by disconnecting it will be the fault. You may however have other underlying faults and only a sweep with Vag Com will tell you that. Hope you got home ok... Link to post Share on other sites
VeedubVR 0 Posted January 14, 2011 Author Report Share Posted January 14, 2011 Yeah back at home, thanks mate. The garage I go to doesn't have vag com but they do another diagnostics machine, will be ok? Phoned TPS and VW and with the exchange they both come to £98.76 inc VAT or £180 without the old unit. Link to post Share on other sites
bungy 2 Posted January 14, 2011 Report Share Posted January 14, 2011 Ouch! Link to post Share on other sites
