VeedubVR 0 Posted January 13, 2011 Report Share Posted January 13, 2011 Story goes, I drove to a car meet, a few miles on the motorway, drove back to meet a few friends. By this time the engine was hot! Oil temp mid 90s, water tempwas smack bang in the middle.However when I went to start it it cut out a few seconds later. Tried again and it cut out instantly. Left it a bit and it went but it fells like its hesitating. Drop the clutch and let it idle and its at about 600-800 and sounds like its got massive cams! And sometimes cuts on. Any ideas? I'm at a car park trying to get home so quick responses will be appreciated!Thanks Link to post Share on other sites
bungy 2 Posted January 13, 2011 Report Share Posted January 13, 2011 Unplug the maf and see if it runs the same Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 Call me a noob but you might have to direct me. I'm not mechanially minded in the slightest haha. What does it do? Can is cause problems unplugged?Thanksc Link to post Share on other sites
bungy 2 Posted January 13, 2011 Report Share Posted January 13, 2011 Mass Air Flow sensor is just up from the airbox and the ECU uses the information in it's calculations. When they are dirty or fail car runs like you describe. It will run disconnected at the plug but if faulty there will be no change in the running. If the running changes when you disconnect it indicates it is ok. Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 The plug that's got 4 wires coming out of the connecter block, like a diamond shape? (You much think I'm such a tool haha)Thanks Link to post Share on other sites
bungy 2 Posted January 13, 2011 Report Share Posted January 13, 2011 Follow the air box back to the throttle body, between the box and the throttle body will be a link with a connector plug. Disengage and pull that out.This is mine on my 4mo. Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 Big difference with it unplugged. Idle is fine now. So what does thaat mean? What do I do now? Link to post Share on other sites
bungy 2 Posted January 13, 2011 Report Share Posted January 13, 2011 Sounds like it is either dirty or faulty, have you got far to drive back. Not sure of the impications of driving without it but it seems to be the problem. Hang on a minute and i'll find out for you. Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 About 7miles back. Cheers mate Link to post Share on other sites
bungy 2 Posted January 13, 2011 Report Share Posted January 13, 2011 IMO opinion I would leave it disconnected and if it runs better take it easy and drive home. Let me know how you get on.... Link to post Share on other sites
craggsy 91 Posted January 13, 2011 Report Share Posted January 13, 2011 Can drive without it for a while so should be fine to get home, ive had one disconnected for about a week before Link to post Share on other sites
bungy 2 Posted January 13, 2011 Report Share Posted January 13, 2011 Cheers Craig, I wasn't sure of the implications until I checked and didn't want to give crap advice. Link to post Share on other sites
craggsy 91 Posted January 13, 2011 Report Share Posted January 13, 2011 Lambda will compensate on the fuel side of things for a while, mine then stopped and wouldnt start till i connected a MAF to it. Luckily i had a new one in the car at the time Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 How do i go about cleaning the MAF? I hope it doesn't need replacing, its had a fortune out of me recently! h Link to post Share on other sites
craggsy 91 Posted January 13, 2011 Report Share Posted January 13, 2011 Cant remember the best stuff to do it with but you can use electrical contact cleaner on it Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 isopropyl alcohol Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 Just clean the connecter block that's got the wires?Just got home.Cheers guysa Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 nope you need to get a isopropyl alcohol spray and spray it into the maf housing mate all over the wire and then let it dry completley before starting up and dont try and rub or touch the wire as its very delicate Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 I have no idea why i have random letters at the end of my messages, damn blackberryWhere cam I get this alcohol spray from?How long can I drive with the MAF disconnected? Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 maplins and electronic places mate or ebay can use electrical contact cleaner but it isnt as good - you will be fine for a day or two with the maf dissconnected Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 Oh ive got electrical contact cleaner in the back of the car. Ill go huting tomorrow for some. Trust it to happen on a weekend when ive got work and garage wont be open. They certainly know how to pick their moments! Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 yeah give it a good soaking mate as even thought they are designed to get very hot and burn off any impurities they do get clogged up fairly easily Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 be easier to clean with the pipe taken off? Might aswel make a start and clean the bay if thats getting removed haha Link to post Share on other sites
Ben Seabrook 4 Posted January 13, 2011 Report Share Posted January 13, 2011 yeah remove the maf housing out mate and clean it off the car - dont want to spray cleaner down into the throttle body Link to post Share on other sites
VeedubVR 0 Posted January 13, 2011 Author Report Share Posted January 13, 2011 if the worst happends how much to replace? Is it easy to replace? Link to post Share on other sites
