HAMMER_VR6 0 Posted December 1, 2010 Report Share Posted December 1, 2010 24v vr6s have plastic inlet manifolds with a VSR system built into them as standard.My question. Can they be adapted to fit the 12v engine, the fact its plastic should help to resist heat soak, and the VSR should improve torque much like a schrick. But without costing ££££ Link to post Share on other sites
UnitedMotorsport 55 Posted December 2, 2010 Report Share Posted December 2, 2010 No, but the American MK4 12v manifold fits right on, and does the same job as the Schrick manifold. Link to post Share on other sites
HAMMER_VR6 0 Posted December 2, 2010 Author Report Share Posted December 2, 2010 [/iNo, but the American MK4 12v manifold fits right on.OK would there be any advantage to fitting one of these? Link to post Share on other sites
HAMMER_VR6 0 Posted December 2, 2010 Author Report Share Posted December 2, 2010 No, but the American MK4 12v manifold fits right on.OK would there be any advantage to fitting one of these? Link to post Share on other sites
Rustyman 0 Posted December 2, 2010 Report Share Posted December 2, 2010 Interesting question ??? i'd like to know too !! Link to post Share on other sites
yakuza racer 16 Posted December 3, 2010 Report Share Posted December 3, 2010 i would be interested as well Link to post Share on other sites
HAMMER_VR6 0 Posted December 3, 2010 Author Report Share Posted December 3, 2010 Dont the american manifolds have the air intake on the left side of the engine bay. (AS YOU LOOK AT THE MOTOR) Link to post Share on other sites
FishWick 21 Posted December 6, 2010 Report Share Posted December 6, 2010 Yep, correct. They also have an electronic throttle and a different rocker cover.To run that manifold you would need the rocker cover, the intake itself, the PCV pipework and fittings, associated plastics and an adapter for the throttle. Although if you're OBD2, your throttle might fit straight on.Pics of the manifold etc here - http://www.gruvenparts.com/website/diys/Performing%20Compression%20Test%20on%20VR6.htmOn top of that, you will also need to remap the ECU to account for the significant torque gain in the lower rpms. The timing will need to be pulled and fuel added where the intake tuning is strongest.By the time you've sourced and imported all those parts, you might be better off finding a s/hand schrick from the UK. Link to post Share on other sites
HAMMER_VR6 0 Posted December 6, 2010 Author Report Share Posted December 6, 2010 Your a knowledgeable chap,Sounds like alot of work and expense, for not alot of gain.Could a 24v inlet be made to fit to your knowledge??????? Link to post Share on other sites
Dave_ciw 507 Posted December 6, 2010 Report Share Posted December 6, 2010 Well Nigel cant take my car in until after Christmas lad he must be a busy character but hey its booked in now anyway.Cheers Rob Link to post Share on other sites
HAMMER_VR6 0 Posted December 6, 2010 Author Report Share Posted December 6, 2010 Hey dave did you go and see him, or just on the phone, Hes real sound bloke and i have had alot of work done there. Just hope he does a good job for you otherwise id feel pretty bad. Link to post Share on other sites
FishWick 21 Posted December 6, 2010 Report Share Posted December 6, 2010 Your a knowledgeable chap' date='Sounds like alot of work and expense, for not alot of gain.Could a 24v inlet be made to fit to your knowledge???????[/quote']It's not as much work as it sounds but it's getting hold of all the bits that's tricky!If you could get a flange made to convert the 24v's square ports to 12v ports and stud pattern, then yeah it should go on. Thinking about how much wider the 24v head is, a 2" thick adapter might bring it right. I'll have to look at in more detail. Got a 24v engine in the garage. One thing though, the intake would have to come off each time you check / change the plugs! Link to post Share on other sites
HAMMER_VR6 0 Posted December 7, 2010 Author Report Share Posted December 7, 2010 I guess if it was simple everyone would be doing it Link to post Share on other sites
Dave_ciw 507 Posted December 7, 2010 Report Share Posted December 7, 2010 Hey dave did you go and see him' date=' or just on the phone, Hes real sound bloke and i have had alot of work done there. Just hope he does a good job for you otherwise id feel pretty bad.[/quote']I just rang him on the blower he said he has 3 restoration projects in. Don't worry about the finish fella I am not the sort that would expect you to feel bad Link to post Share on other sites
