rsweeney 40 Posted November 20, 2010 Report Share Posted November 20, 2010 i unexpectingly found today that the automatic gearbox oil cooler is clogged up with half a ton of stuff ( possably radweld from previous owner.) Unfortunatly it is a sealed unit how do i go about removing the clooged up stuff as it isnt rockhard its almost like wet sand . here is a pic of the cooler Link to post Share on other sites
Antihero1981 8 Posted November 21, 2010 Report Share Posted November 21, 2010 i would try maybe a high pressure hose ect , the water wont flow to quick as i am pretty sure its like a rad inside , i have hooked mine up to an external cooler to help reduce heat even more Link to post Share on other sites
rsweeney 40 Posted November 21, 2010 Author Report Share Posted November 21, 2010 cheers , the power hose worked a treat and all the gunk has washed through. all i can say is that radweld is a total waste of money... out of interset how does it run with the external cooler ? Link to post Share on other sites
CALICO 130 Posted November 21, 2010 Report Share Posted November 21, 2010 im interested Antihero as i/ll be running turbo and auto have you got temp sensor in the gearbox Link to post Share on other sites
Antihero1981 8 Posted November 21, 2010 Report Share Posted November 21, 2010 no temp sensor , i have hooked mine up to the charge cooler return so water flows from tank in boot to charge cooler > passes through charge cooler then directed to gearbox cooler then through mini rad then back to tank in boot the temp from the charge cooler should keep the gearbox at a nice level , you dont want to cold as it will damage and you dont want to hot eitheri am running 300bhp through the standard auto box and so far so good 2 years later no issues...touch wood...lol....i got a 12 litre tank in boot for charge cooler set up Link to post Share on other sites
CALICO 130 Posted November 22, 2010 Report Share Posted November 22, 2010 very very nice be good to have a look sometime Link to post Share on other sites
