tomhughes 0 Posted November 13, 2010 Report Share Posted November 13, 2010 Hi guys, i have just bought a P reg vr6 highline and have a few warning light problems i need some advice with.firstly, the ABS warning light was on, the garage says it needs a new pump and modulator. the part number is the dreaded 1H2 614 217 C which seems to be as rare as rocking-horse shit! but found one with an E on the end instead of the C, which i am led to believe is just an upgraded version. is this correct? well i fitted it anyway, and the light was still on, so i looked into it on some forums and found it can get mis-diagnosed and could just be a sensor. i found a faulty one and replaced that but the light is still on, so im out of ideas with it now. any help would be apprieciated.secondly, the general handbrake warning light has come on since i replaced the sensor, though i have checked them all and they all work so im unsure what the problem with that is. Link to post Share on other sites
rosserooni 0 Posted November 13, 2010 Report Share Posted November 13, 2010 Have you put it on a diagnostics machine it should tell you exactly whats wrong. Link to post Share on other sites
tomhughes 0 Posted November 13, 2010 Author Report Share Posted November 13, 2010 the garage did, and it said the pump and modulator were faulty. but i have replaced these and the light is still on. :-( Link to post Share on other sites
naffa 0 Posted November 13, 2010 Report Share Posted November 13, 2010 you need to get it back on the computer to erase the original fault codes, your light will then go out. Link to post Share on other sites
tomhughes 0 Posted November 13, 2010 Author Report Share Posted November 13, 2010 ah cool, will see how it goes. any help with the general/hanbrake light randomly coming on after i fitted the abs sensor? Link to post Share on other sites
Dave_ciw 507 Posted November 13, 2010 Report Share Posted November 13, 2010 I am not sure the E is the predecessor to the C?? Once all sensors are confirmed by vag com to be good get your original pump fitted. Then clear Fault codes on your ECU. I had a customer looking one of these pumps and they were quoted over £1000 for it from VW. If that doesnt sort it a lad has done some soldering fix on his pump. Link to post Share on other sites
tomhughes 0 Posted November 13, 2010 Author Report Share Posted November 13, 2010 yea i was quoted at £870 fully fiited from the local garage, was trying to avoid splashing out. though i suppose i could fit the damn thing myself and buy it at trade price to save a few quid if the fault clearing doesnt work..... Link to post Share on other sites
Rikki 2 Posted November 13, 2010 Report Share Posted November 13, 2010 If its a later car i think the ecu needs to be coded which may be why your light is still on. Does the ABS work at all? Link to post Share on other sites
