richgti97 0 Posted October 6, 2010 Report Share Posted October 6, 2010 I have a set of 17" porsche twists.. fronts are 7in and rears are 8.5in. I will be fitting 195/40 on the fronts so shouldnt have a problem with rubbing as i have had the arches rolled and the pcd adaptors are 20mm. However i am after any advice on the rears, i will be fitting 225/35 tyres and hopefully the rolled arches will be enough to stop rubbing on the outside but can anybody shed any light on weather 20mm will push the 8.5in rim out enough to clear my coilovers.. as there isnt a great deal of clearance between the inside of tyre and the spring of the coilovers as it is with standard wheels..and obv the offsets are differnt too. Link to post Share on other sites
legvw 0 Posted October 6, 2010 Report Share Posted October 6, 2010 I think there is an offset calculator on here somewhere.As long as you know your original wheel offset and width, and your new wheel offset and width it should tell you if the will fit with more or less clearance.Heres another http://www.1010tires.com/WheelOffsetCalculator.asp Link to post Share on other sites
VeedubVR 0 Posted October 6, 2010 Report Share Posted October 6, 2010 go for a 195/40 or a 205/40 on the back instead of a 225/35.Try and get falkens as they stretch really well nd have a smaller side wall. Im runing 195/40s on a 8J and maybe on a 9 if I get bigger barrels. Its all down to Offset. Porsche wheels generally have a high offset between 50-60. How are you wanting the wheels to sit?Im running ET20 and ET10 but my wheels are 8J. Link to post Share on other sites
richgti97 0 Posted October 7, 2010 Author Report Share Posted October 7, 2010 I will look up this calculator. cheers.I dont really want to run a massive stretch.. and ideally want the oputside of the rim sitting inline with the arches. At the min my car is on about a 70mm drop, cant go lower for sump reasons! Link to post Share on other sites
Ian_rogers 0 Posted October 7, 2010 Report Share Posted October 7, 2010 http://www.1010tires.com/WheelOffsetCalculator.asp?CWW=7&CWO=32&NWW=7.5&NWO=42&strut=&wheeloutside=Offset calc Link to post Share on other sites
