leigh vr6 0 Posted August 29, 2010 Report Share Posted August 29, 2010 hi i have a n reg golf cabrio vr6 was running fine the other day now it wont start turns over starts then cuts out after a few secs my scanner says its the immobiliser so i changed the box key reader and key with chip for that box but still does the same ifbi disconect the battery for 5 mins then connect it back up the car will start but if i turn it off then try to restart it wont again any help plz Link to post Share on other sites
cabrioman 6 Posted August 29, 2010 Report Share Posted August 29, 2010 get the immobiliser removed from the ecu mate is the easy way ... have a word with united motorsport on here they should be able to sort it out for you mate Link to post Share on other sites
leigh vr6 0 Posted September 1, 2010 Author Report Share Posted September 1, 2010 if i was to get another ecu with the same part number and plug it in will this solve my problem Link to post Share on other sites
CALICO 130 Posted September 1, 2010 Report Share Posted September 1, 2010 have you tried replacing the ring around the igniton key hole another ecu with the same numbers wont help they are all individually coded Link to post Share on other sites
leigh vr6 0 Posted September 1, 2010 Author Report Share Posted September 1, 2010 ive replaced the ring chip and box from a car that was working fine but still does the same Link to post Share on other sites
LadVR 0 Posted September 1, 2010 Report Share Posted September 1, 2010 Im currently having the same issues too! I have changed the ring around the ignition barrel, made no difference, also checked and re checked all the electrics but no joy.After hours of research on the internet (many hours worth) it looks like we have 2 options.;1. replace transponder - you'll need to get it recoded by vw or someone with the software to match ket, ecu, transponderor2. Use a company who can recode the ecu to bypass the transponder (i think c2 offer this service) Link to post Share on other sites
leigh vr6 0 Posted September 1, 2010 Author Report Share Posted September 1, 2010 spoke to vw today thay said thay will put on diagnostic and if the key needs re codeing it will cost about £70 Link to post Share on other sites
Savage K 0 Posted February 28 Report Share Posted February 28 Am having the same issue , replaced coil pack, fuel pump relay , and crankshaft position sensor and still no joy 😢 Link to post Share on other sites
