Sidhu88 1 Posted September 2, 2011 Report Share Posted September 2, 2011 "Built not broken" Link to post Share on other sites
bethslad 1 Posted September 2, 2011 Report Share Posted September 2, 2011 Mate don't break it up ill be honest there's a few bits on your list id like but i think we would rather have the vr sorted if possible than take your vr to bits, im nae much help being new to the vr scene but im sure there plenty of guys on here with shed loads of advice to sort your motor out ;-) Link to post Share on other sites
*P3nfold* 0 Posted September 2, 2011 Author Report Share Posted September 2, 2011 Don't cams take a little while to bed in' date=' have you tried engine flush that could help with noisy lifters sometimes?[/quote']Never used engine flush before, i guess its quite simple? Link to post Share on other sites
*P3nfold* 0 Posted September 2, 2011 Author Report Share Posted September 2, 2011 Mate don't break it up ill be honest there's a few bits on your list id like but i think we would rather have the vr sorted if possible than take your vr to bits' date=' im nae much help being new to the vr scene but im sure there plenty of guys on here with shed loads of advice to sort your motor out ;-)[/quote']Cheers fella. I a few more bits to check and then I am out of money.As you have mentioned there are quite a few guys on here that have been awesome with advise, help, guidance etc...The forum is excellent. Link to post Share on other sites
*P3nfold* 0 Posted September 2, 2011 Author Report Share Posted September 2, 2011 There are a few parts I need to sell as money is so tight, so they will go on the forum this weekend.6 branchO2A gearboxGreen stuff padsCompression plateAnd some other bits. Link to post Share on other sites
rodney 17 Posted September 2, 2011 Report Share Posted September 2, 2011 One daft thing and I am sure the answer is yes... but as you changed cams etc did you do an oil change after the install...? (queitly... shhh... and checked the levels) Link to post Share on other sites
*P3nfold* 0 Posted September 2, 2011 Author Report Share Posted September 2, 2011 I removed the rocker cover lined up the bottom end on the TDC and did not see the same slack as before, without the cam locking plate it looked fine. Actually everything looked fine but i'm no mechanic. Link to post Share on other sites
*P3nfold* 0 Posted September 2, 2011 Author Report Share Posted September 2, 2011 One daft thing and I am sure the answer is yes... but as you changed cams etc did you do an oil change after the install...? (queitly... shhh... and checked the levels) I did indeed. Link to post Share on other sites
rodney 17 Posted September 2, 2011 Report Share Posted September 2, 2011 this seems like Deja vue some how. Did Tony hear the rattle??? I forget... Link to post Share on other sites
craggsy 91 Posted September 2, 2011 Report Share Posted September 2, 2011 All us FI boys had teething problems Martin.....mine was off road for about 10 days with a mystery problem that I sorted out with many many calls to Tony.Stick at it......its all worth it when you floor it and leave expensive machinery behind Link to post Share on other sites
*P3nfold* 0 Posted September 2, 2011 Author Report Share Posted September 2, 2011 All us FI boys had teething problems Martin.....mine was off road for about 10 days with a mystery problem that I sorted out with many many calls to Tony.Stick at it......its all worth it when you floor it and leave expensive machinery behindMight leave some R32T behind Craig!!!! Link to post Share on other sites
*P3nfold* 0 Posted September 2, 2011 Author Report Share Posted September 2, 2011 this seems like Deja vue some how. Did Tony hear the rattle??? I forget...Unfortunately not as Tony and I agreed to get the top stripped off, to reduce time. Link to post Share on other sites
rodney 17 Posted September 3, 2011 Report Share Posted September 3, 2011 can you record (on your phone?) and pop on here so we can listen for you??? Link to post Share on other sites
Daverse 175 Posted September 3, 2011 Report Share Posted September 3, 2011 is the arp head kit used? if not how much?The kit is used' date=' was from Craggys build. ARP head stud kits are meant to be reused!! If you are interested I will put them onto the sales board?[/quote']how much were you thinking? Link to post Share on other sites
*P3nfold* 0 Posted September 4, 2011 Author Report Share Posted September 4, 2011 Daverse, not sure need to think about pricing etc... Will PM you once I put it on the sales board? Are you looking for a compression plate as well? Link to post Share on other sites
*P3nfold* 0 Posted September 4, 2011 Author Report Share Posted September 4, 2011 I took her out yestereday evening for a good drive and she idles better.I did notice that on the down change alot of burble and the acceleration is not smooth, around 3500rpm when the engine comes onto positive boost the car suddenly pulls funny, like a turbo.Hard to explain is if the power is not completely there and then suddenly just is. Does not feel right?Checked the MAF wiring and is wired correctly, not contact issues.Vag.com is clean, no errors. Engine sounds better excluding the tappets noise.I will move the MAF and parts to the passenger side. Link to post Share on other sites
*P3nfold* 0 Posted September 11, 2011 Author Report Share Posted September 11, 2011 Some progress, move the MAF another 2 inches and idling is not really that much better to be honest.I am still only getting about Max 4.5 psi boost.So a few more picturesOh yes its only taken me 3 months to get the sticker made but "vag whore" is missing from the bottom right corner.Took a leaf out of Tony and Pauls book an created some customer pipework with bits and bobs.Its only taken me 5 months to wrap this, what a pain in the a** but well worth it, as I am about to sell them :-(I also had to raise the car up around 15mm for the temp hash for the induction kit. Once I got more pennies I will get a BMC and put this under the passenger wing with the MAF and will run the pipework behind the front splitter. Link to post Share on other sites
*P3nfold* 0 Posted September 15, 2011 Author Report Share Posted September 15, 2011 Well I the idle is better, I went to Vince at Stealth Racing to sort the tappets and re-map the car and this has made a huge difference.Confidence is back on top. Fitted the rear strut brace, the MAF is further away from charger and the air filter is in the passenger side of the bumper. Free oil catch can fitted from an old charger setup, cheers Stealth. Oh I dropped the car back to the usual ride height.So on that note I have got loads of spare parts to sell including to United map which was not really suited to my application in the end.Oh on the rollers I got 270bhp and 233 lb ft which is a little disappointing tbh but with a move the plastic casing around the filter and sports cat, I am convinced this will make 285bhp + with some additional torque I hope. Link to post Share on other sites
rodney 17 Posted September 16, 2011 Report Share Posted September 16, 2011 Yayyyyyyy good ol' VinceI can feel the smile and the up-beat feeling just from your post... I trust you are enjuying yourself... Link to post Share on other sites
*P3nfold* 0 Posted September 17, 2011 Author Report Share Posted September 17, 2011 Hey RCF, the VR is working fine, having a cold start issue but hopefully this will be sorted with the engine coolant sensor thing.Only issue I have now is the rear passenger foot weld has water in it and the rear passenger door window has dropped down and the motor will not push it up. Link to post Share on other sites
rodney 17 Posted September 17, 2011 Report Share Posted September 17, 2011 Ahhh I suffered that... may I suggest you pop the panel off and insert a Piece of wood to hold it up whilst you get the new mech... worked for me... Link to post Share on other sites
*P3nfold* 0 Posted September 17, 2011 Author Report Share Posted September 17, 2011 I used a gaffa tape and zip ties lol but the wood sounds like a better idea. Link to post Share on other sites
*P3nfold* 0 Posted September 17, 2011 Author Report Share Posted September 17, 2011 Graphs and data from the mapping session at Stealth. Link to post Share on other sites
jims13 6 Posted September 17, 2011 Report Share Posted September 17, 2011 mmm nice graph ... your problem when driving still exsists , the graph shows that, vince has just mapped around it.. that would explain your low trq readings Link to post Share on other sites
*P3nfold* 0 Posted September 17, 2011 Author Report Share Posted September 17, 2011 Hey Jim. what do you mean by your problem when driving still exists fella?I must say the maps are very different. Link to post Share on other sites
