Spark Plugs.... Are they worth a little extra??
Hey Guys...
Just wondering if there is any real noticable difference between the Bosch spark plugs and the NGK ones... the problem i have is i want to change the plugs so they are nice and fresh so i dont have to worry about them for a while.... but im skint... i dont want to spend out £7 or £8 per plug for NGK ones if they aren't THAT different to the £2 or £3 Bosch ones from GSF.
I need some opinions from people who have run both because when buying 6 of them it works out a lot of difference and if the Bosch ones do the job nicely then ill go for them...
Thanks in advance :) :)
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
Well you know what happened to jakes engine on Bosch plugs' date=' I'm sure jim had a problem too. I run ngk as does tony, jim and a fair few others.
Mine didn't run right with Bosch plugs either so swapped to ngk and ran better
what happened to jakes engine????
