long story but alarm on car is a crap fox guard or something anyways the fob has broke and no longer opnes the door with the remote locking or diabsles the aftermarket imobiliser.
after a few swear words and cutting stripping and rejoining wires the imobiliser is now disarmed in away that the car cranks over but wont start like its got the fuel cut is this maybe a secondary imobiliser? or has it been wired the the fuel pump?
follow the wires from the immobilizer box, all wires are typically black. follow them to wires that arent black, and cut and join the wires they join to. Color for color. So if there are 4 black wires, leading to 2 red wires and 2 green wires. Cut the 4 black wires and join them so the 2 green wires join again and so that the 2 red wires join again.
where is the imobilisier box on the car?
remove your ignition cowling then you will see a cirle around the ignition barrel follow the wires from there to a black box under the dash
you might just need to replace the ring around the ignition
Get the car on VAG com, I am having a similar problem at the minute myself. Aftermarket alarm and immob removed, but factory one now has no code in it so won't run. Going to get keys programmed some day in work, will keep ypu posted
