Another problem with the car now.
Every time I go round a roundabout a bit quick the car sort of hesitates / cuts out until I've slowed down a bit or straighten up. Fine around left bends, just the right!
It was doing it just before the headgasket went and since getting it done it's had new plugs, leads, etc, etc. Had a second hand coil pack put on it because the original one was cracked!
Any help would be much appreciated!
I had this problem in my mk3, rattled my brains for months trying to fix it....
It ended up being a loose wire on my ECU that kept on causing the revs to drop, which caused it to cut out. there was a tiny bit of movement on the ecu, which was enough to break the connection.
might not be that at all, but I thought I'd share experience with others.
