dash board
easy mate..
pop out the blank on right hand side (no1 above)
on end of headlamp switch is a press in clip. press it in. switch comes out.
pop out the blank on left side (no3 above)
remove 2 screws arrowed above holding the surround in
surround will now pop out.
2 screws will now be visible that hold in the dials..
undo, lean dials forward, unplug loom and remove..
job done with minimal swearing hopefully *-)
naaah, easy mate! even i can do it!!!
if you have never done it before be careful not to break anything levering them out of the dash, a small flat blade driver will be fine.. just prise carefully.
should take about 15 mins if, as i say, you have never done it before.
putting it back together will much easier, will take about 2 mins :)
