corradogang* 0 Posted December 6, 2004 Report Share Posted December 6, 2004 ive just orderd some rather nice konig e-racer black alloys .when they were deliverd i struggled 2 get them 2 fit properly the holes dont line up 100% . 2 get the whells to run strait is a near impsossibility , hte tyre place managed it but i cant.can any1 please help me im at my wits end ,the spacers they sent me werent big enough so i bought some thicker ones but used the same bolts [i think theyre a touch 2 short Link to post Share on other sites
MrBen 0 Posted December 6, 2004 Report Share Posted December 6, 2004 Are they definitely the right fitment? Sounds a bit odd that the bolt holes don't line up! Why did they come with spacers? Again, sounds like they are the wrong offset too? Link to post Share on other sites
corradogang* 0 Posted December 6, 2004 Author Report Share Posted December 6, 2004 its only ever so slight but its enough to make them a nightmare .it seems that they dont actualy fit snugly to the hub. i orderderd them form a company called wheel base [in middle of max power]i asked them for some wheels FOR my corrado ! surly its up to them to know what wheel fits wictch carnow they say theryre used and they wont have them back mean while i was driving down the road and nearly all the bolts come out!!! imadgine if id been doin over a 100 ![not good] Link to post Share on other sites
tommy 0 Posted December 6, 2004 Report Share Posted December 6, 2004 yeah they sound like the wrong pcd and et...........should be 5x100 with an et of somthing like 35 but this will change depending on the width of the rim......you should find a stamp on on the wheel saying the pcd and et Link to post Share on other sites
tommy 0 Posted December 6, 2004 Report Share Posted December 6, 2004 &| &| Doh???you replied before I had a chance to finish typing that........are you sure you have the right length wheel bolts...I had to take off the rh wheel bolts on my wheels as they were to long....the wheel would do up but I got a vibration when driving......changed them for shorter ones and it went away![ Edited Mon Dec 06 2004, 11:04PM ] Link to post Share on other sites
corradogang* 0 Posted December 6, 2004 Author Report Share Posted December 6, 2004 how do mean 5 time 100 Link to post Share on other sites
corradogang* 0 Posted December 6, 2004 Author Report Share Posted December 6, 2004 the ect is 45 but i do not see any numbers like 100 anywere Link to post Share on other sites
VR6Rich 3 Posted December 6, 2004 Report Share Posted December 6, 2004 PCD : 5x100 = 100mm between each hole (5). Link to post Share on other sites
MrBen 0 Posted December 6, 2004 Report Share Posted December 6, 2004 5x100, means there are 5 bolts, and if you imagine a circle going through the middle of them, the diameter of that circle is 100mm. It's usually detailed somewhere on the back of the wheel. I think your first mistake may have been using a company listed in Max Power! But still, they should be capable of selling the correct wheels. If the wheels are wrong, then it doesn't matter if you have fitted them, they are required by law to sort out the situation. Link to post Share on other sites
corradogang* 0 Posted December 6, 2004 Author Report Share Posted December 6, 2004 the thing is ive marked them trying in vain to get them to fit Link to post Share on other sites
VR6Rich 3 Posted December 6, 2004 Report Share Posted December 6, 2004 I stand corrected! Link to post Share on other sites
MrBen 0 Posted December 6, 2004 Report Share Posted December 6, 2004 the thing is ive marked them trying in vain to get them to fit This does make it a little more difficult, but still it does appear they have sold you the wrong product. I'm no expert on such matters, but you must have a case against them. Any trading standards experts on here?? Link to post Share on other sites
binliner 0 Posted December 7, 2004 Report Share Posted December 7, 2004 phone them and tell them the problem and check exactly what theyve sent you Link to post Share on other sites
acf8181 0 Posted December 7, 2004 Report Share Posted December 7, 2004 get the wheels off right now...they're obviously not right and its an accident waiting to happen.then do a google search for trading standards, shouod bring up some info. i'm pretty sure as the product they've sold you is incorret they have to refund you. Link to post Share on other sites
stu h 0 Posted December 7, 2004 Report Share Posted December 7, 2004 ''goods have to be fit for the purpose they are sold for'' sale of goods act 197?something like that if i remember correctly. see!! i learnt sumfing at schul.....[ Edited Tue Dec 07 2004, 09:43AM ] Link to post Share on other sites
BigSi 0 Posted December 7, 2004 Report Share Posted December 7, 2004 Don't some of the other cars in the VAG range have 5 x 112 filaments, such as the Passat?Just wondering if this is the mistake? - although I wouldn't have thought you would be able to get more than 2 bolts in as they would be quite a way out.You're on sticky ground for the return seeing as you have damaged them - yes you can quote about not being "fit for purpose" you can use this when an item is basically crap or if it is the wrong part, which sounds to be the case here. But that doen't allow you to damage them by trying your best to make it fit. If you had just held the wheels up to the car, spotted that they didn't fit, rung the supplier saying they were wrong you would have had no problems.Best thing you can do is ring them - go over the problem of them not fitting, see if you can spot what is wrong and then discus the return/exchange.Depending on the level of damage you will probably have to cover some of the cost.best of luck! Link to post Share on other sites
corradogang* 0 Posted December 7, 2004 Author Report Share Posted December 7, 2004 thanx you have been realy helpfull Link to post Share on other sites
acf8181 0 Posted December 7, 2004 Report Share Posted December 7, 2004 let us know what happens, best of luck. Link to post Share on other sites
corradogang* 0 Posted December 8, 2004 Author Report Share Posted December 8, 2004 found out what it is .its the bolts, the taper by the head of thye bolt is so wide the bolts dont sit on the whellls properly Link to post Share on other sites
blackburnvr6 0 Posted December 8, 2004 Report Share Posted December 8, 2004 surly they should have given you a fitting kit with it every time i have bought wheels they always have dont sound a good company to me but least you got it sorted Link to post Share on other sites
stu h 0 Posted December 8, 2004 Report Share Posted December 8, 2004 glad you sorted it mate Link to post Share on other sites
