dru 0 Posted October 11, 2009 Report Share Posted October 11, 2009 anyone one elses vr drive rubbish when its cold my will only rev to 3k then only fires on 5 and the wholecar shakes for a bit until it warms up its all fine any ideas aprt from let it warm up lol Link to post Share on other sites
hvr6 88 Posted October 11, 2009 Report Share Posted October 11, 2009 i always let mine warm up before driving :-) Link to post Share on other sites
cabrioman 6 Posted October 11, 2009 Report Share Posted October 11, 2009 could have a prob there mate get it vag comed .... Link to post Share on other sites
dru 0 Posted October 11, 2009 Author Report Share Posted October 11, 2009 no faults stored vag'd it this evening Link to post Share on other sites
cabrioman 6 Posted October 11, 2009 Report Share Posted October 11, 2009 hmmmm well that aint rite mate could be a sensor goin down or something like .... oh hang on hows ur coil pack ??? is it worse when colder or wet ??? Link to post Share on other sites
dru 0 Posted October 11, 2009 Author Report Share Posted October 11, 2009 colder mate but once the water temp needle gets to about 90oc its fine and usually when driving it before the idle settles down its at its worse, it misfire but never stalls Link to post Share on other sites
cabrioman 6 Posted October 11, 2009 Report Share Posted October 11, 2009 could be a cracked coilpack mate ...... Link to post Share on other sites
craggsy 91 Posted October 11, 2009 Report Share Posted October 11, 2009 blue temp sensor? Link to post Share on other sites
dru 0 Posted October 11, 2009 Author Report Share Posted October 11, 2009 will check it out tomoz just had a new coil pack fitted just before i got it so if it is sholuld be a waranted part also has a very holey exhaust could this contribute? Link to post Share on other sites
J5KE F 0 Posted October 11, 2009 Report Share Posted October 11, 2009 Coil packs have a tendency to show little sparks in the dark if it's pants, but not likely if new..!people will chuckle at this coming from me but have u checked the plugs and leads..? Link to post Share on other sites
craggsy 91 Posted October 11, 2009 Report Share Posted October 11, 2009 LOL Link to post Share on other sites
J5KE F 0 Posted October 11, 2009 Report Share Posted October 11, 2009 An I just knew it'd cum from oop norf! Tanks craig x Link to post Share on other sites
rodney 17 Posted October 12, 2009 Report Share Posted October 12, 2009 Yes the blowing zorst will contribute...Cold weather highlights weakness in the electrical system as it has to work harder to produce the same level of elastiktrikkery...So yes you need to check the usual suspects of dizzy/coilpack, Plug leads and plugs... Basically everything has bigger gaps as they shrink in the cold... I'm sure you can understand... .. so anything which relys on a gap or has a gap will generally be bigger so listening to what you're saying basically once everything is warm then they are all as they should be... so yup try these basics and then we can go from there... Link to post Share on other sites
dru 0 Posted October 13, 2009 Author Report Share Posted October 13, 2009 checked all today coil pack seems fine but plugs look like theyve seen better days, so leads and plugs are the next change on the list , but i rev the engine as far as i could whilst it was cold and stood still and it did stall and then struggld to start again? took a few goes but got it running but missing for a bit, its also used a bit of oli and water in the last few days???? Link to post Share on other sites
grafteratwork 2 Posted February 24, 2010 Report Share Posted February 24, 2010 bump Link to post Share on other sites
james4287 1 Posted June 6, 2010 Report Share Posted June 6, 2010 see here http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?185177.0 Link to post Share on other sites
