Geastb 0 Posted December 2, 2004 Report Share Posted December 2, 2004 I've fitted a momo boss kit and steering wheel (inc snap off kit) and i have 2 problems:1) When using the turn signals they don't automatically switch off after turning corners (i've turned the steering wheel completly 360 deg to check the boss isn't mounted in the incorrect postion)2) With the snap off kit fitted the steering wheel is too far away from the indicator and washer stalks.Has anyone else had these problems - if so how did you get round them? Link to post Share on other sites
acf8181 0 Posted December 2, 2004 Report Share Posted December 2, 2004 1) are sure its the right boss for the car, should have a bit coming out to switch off the indicators.2) you'll get used it. Link to post Share on other sites
binliner 0 Posted December 2, 2004 Report Share Posted December 2, 2004 are the first and second problems connected possibly? Link to post Share on other sites
Geastb 0 Posted December 3, 2004 Author Report Share Posted December 3, 2004 It has the little lug for switching off indicators but it don't seem to connect! I've heard there is a collar that can be removed on the steering?? I'm assured its the correct boss kit! Link to post Share on other sites
binliner 0 Posted December 3, 2004 Report Share Posted December 3, 2004 there is a collar on the mk3 that makes the splined bit wider... that can be removes and underneath there is the narower one the same as on a mk2 but if the wheel is on it cant be that? or am I thinking of the wrong thing? Link to post Share on other sites
Geastb 0 Posted December 3, 2004 Author Report Share Posted December 3, 2004 How do you remove the collar? I might try that to see if it helps. I can always put it back on i suppose? Link to post Share on other sites
binliner 0 Posted December 3, 2004 Report Share Posted December 3, 2004 I took it to my mate who works at a vw specialist... basically you need some sort of pulling tool (the name of which escapes me at the moment) Link to post Share on other sites
Geastb 0 Posted December 3, 2004 Author Report Share Posted December 3, 2004 Cheers Binliner - I'll see if i can find somewhere round here that can help! Link to post Share on other sites
Heardy 0 Posted December 11, 2004 Report Share Posted December 11, 2004 I had same problem the wheel being too far away on my corrado,i ended up getting a different momo boss (a shorter one) and what you need to do is to unbolt the centre part of the boss and swap it for a shorter one.. Link to post Share on other sites
