Misfire please help (what else could it be)
Well like I said before get the injectors out into jars to check spray pattern and quantity to rule out dodgy injector....or swap over 2 injectors
done that... and all have been sonic cleaned and pattern tested
tony numbers on ecu are
Bosch
0 261 203 968/969
021 906 256
24 little vw sign 74
date 14.06.96
26sa4098
1739 0326
mate i had 2 mega missing problems on my old cavalier gsi one of them turned out to be tesco petrol which is apparently the worst grade of fuel you can buy ! and the other time was the engine temperature sensor which was broke and it was telling the ecu that the car was running hot(even when it was stone cold) so then the ecu was flooding the chambers with fuel to try and cool it down. but all it was doing was making the engine miss and backfire !
ill check mine tomo but like i said has the imlblizer on it so wont run yet ..... pop the numbers up and see if someone lend u a spare one ???
don't think anyone will be up for it but ill give it ago.
Does this mean that i need the immobilizer disabling off the next ecu to try it im my car? was hoping that was done between that black box by the column and the key
