Timah89 1 Posted May 18, 2009 Report Share Posted May 18, 2009 My ABS light just randomly came on today, cant see any clear reason why, any one have any ideas? Link to post Share on other sites
craggsy 91 Posted May 18, 2009 Report Share Posted May 18, 2009 dodgy sensor Link to post Share on other sites
Ben Seabrook 4 Posted May 18, 2009 Report Share Posted May 18, 2009 this happened to mine and it turned out to be the pump - get it on vag-com mate and it will tell you what the fault is Link to post Share on other sites
Timah89 1 Posted May 18, 2009 Author Report Share Posted May 18, 2009 where is the sensor located? Link to post Share on other sites
craggsy 91 Posted May 18, 2009 Report Share Posted May 18, 2009 one at each wheel Link to post Share on other sites
legvw 0 Posted May 18, 2009 Report Share Posted May 18, 2009 My abs light used to come on after i took my vr over 120mph! Every time, with out fail. Would only go off after i'd switched everything off! But yeah, possibly a sender, might just need a clean? Link to post Share on other sites
Timah89 1 Posted May 18, 2009 Author Report Share Posted May 18, 2009 cool, i'll try and give them a clean at the weekend then and see what happens!cheers all Link to post Share on other sites
Timah89 1 Posted May 19, 2009 Author Report Share Posted May 19, 2009 can anyone give me a guide on the easiest way to check the sensors and clean them? are they fiddly to get too at all? the light is permanently on now! ! Link to post Share on other sites
craggsy 91 Posted May 19, 2009 Report Share Posted May 19, 2009 ideally get it on VAGCOM then you will know what sensor needs replacing straight away Link to post Share on other sites
Timah89 1 Posted May 19, 2009 Author Report Share Posted May 19, 2009 shall do,think my bro has got vag com so will give it a shot on Saturday morning! cheers Link to post Share on other sites
Timah89 1 Posted May 27, 2009 Author Report Share Posted May 27, 2009 right then, now my ABS light is starting to flicker off. However........the brakes now are very dodgy, grinding noise and sort of come on and off.......possible pump problem. Really need help now peeps.......what do i do?? Link to post Share on other sites
Dave_ciw 507 Posted May 27, 2009 Report Share Posted May 27, 2009 Did you manage to get her on VAGcom buddy??? I have it but im the other side of shrewbury from you matey..... Link to post Share on other sites
Timah89 1 Posted May 27, 2009 Author Report Share Posted May 27, 2009 my bro has just brought it over tonight, so day off work tomorrow and will hook it up. Bit scared though now cause pump can be very expensive from what i hear! Just what i need! Link to post Share on other sites
Ben Seabrook 4 Posted May 27, 2009 Report Share Posted May 27, 2009 just changed the pump on mine mate - bought a second hand one for £40 and took about 2 hours to change it all over and then another hour or so to bleed the brakes and the pump - not a very tricky job either Link to post Share on other sites
SankysVR6 1 Posted May 28, 2009 Report Share Posted May 28, 2009 Moved post to the correct section Link to post Share on other sites
Timah89 1 Posted May 28, 2009 Author Report Share Posted May 28, 2009 sweet, i'll check out my local scrappy for a pump then, fingers crossed that sorts this problem out then. Thanks for moving the thread too. Link to post Share on other sites
Timah89 1 Posted May 28, 2009 Author Report Share Posted May 28, 2009 one more thing, where is the VAG-COM port located? Link to post Share on other sites
Ben Seabrook 4 Posted May 28, 2009 Report Share Posted May 28, 2009 pull the ashtray out and then slide the piece of plastic trim to the left of that out and bingo :) Link to post Share on other sites
Timah89 1 Posted May 28, 2009 Author Report Share Posted May 28, 2009 sweet, much appreciated, should be able to update late on then.thanks, Link to post Share on other sites
Timah89 1 Posted May 28, 2009 Author Report Share Posted May 28, 2009 Right then, VAG-COM done, below are the faults, any ideas on how i can clear all these? didnt quite expect all of these to come out of it!! Address 01: Engine Controller: 021 906 256 Component: MOTRONIC M3.8.1 HS V02 Coding: 00000 Shop #: WSC 013173 Faults Found:17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent00522 - Engine Coolant Temperature Sensor (G62) 27-10 - Implausible Signal - Intermittent00553 - Mass Air Flow Sensor (G70) 31-10 - Open or Short to Ground - IntermittentReadiness: N/A-------------------------------------------------------------------------------Address 03: ABS Brakes Controller: 3A0 907 379 A Component: ABS/EDS ITTAE 20 GI V00 Coding: 03604 Shop #: WSC 000002 Faults Found:00283 - Front Left ABS Wheel Speed Sensor (G47) 35-00 - -00283 - Front Left ABS Wheel Speed Sensor (G47) 16-10 - Signal Outside Specifications - Intermittent Link to post Share on other sites
Timah89 1 Posted May 28, 2009 Author Report Share Posted May 28, 2009 as for the brakes, i think i may have an air bubble in the lines or something, gonna try and bleed them over the weekend and see what happens. will clean the faulty sensor too. Link to post Share on other sites
Timah89 1 Posted June 1, 2009 Author Report Share Posted June 1, 2009 can anyone help with any of this? Link to post Share on other sites
Ben Seabrook 4 Posted June 1, 2009 Report Share Posted June 1, 2009 did you try and bleed the brakes mate ? as vag-com has popped it up I would suggest that the sensor it noted 00283 - Front Left ABS Wheel Speed Sensor (G47) is worth replacing - they are able to stand a fair amount of dirt etc and still work - with vag-com the thing to do is always save the codes then run it again to see what "live" problems you have Link to post Share on other sites
Timah89 1 Posted June 2, 2009 Author Report Share Posted June 2, 2009 i'm gonna try and take the sensor out tonight then replace it, any idea on costs for new ones? i'm hoping that fixes the problem then without having to bleed them. we shall see though, knowing my luck i'll need to replace the whole brake system haha. Any ideas on how i would fix the other problems too, coolant sensor (where is that particular one located) and the MAF sensor, only cleaned that a little while ago. But it does feel like it struggles abit low end sometimes. thanks Link to post Share on other sites
Ben Seabrook 4 Posted June 2, 2009 Report Share Posted June 2, 2009 the sensor's are pretty expensive from memory they are about £15 plus vat from GSF - replacing the ABS pump isn't too big a job but bleeding the system is a faf have you tried cleaning the MAF ? Link to post Share on other sites
