Removing ABS ECU, any help appreciated
Hi all, I am suffering from apparently the usual ABS issues. i have swopped the rear speed sensors *(under back seat) and the RR fault re-appears pointing to a replacement ECU? has anyone removed one of these with the pump left in situ, how difficult is it and have they got instructions.
cheers in advance.
Steve
1997 Golf, Dragon green
Hi, this was the 1st vag com:-
Address 03 -------------------------------------------------------
Controller: 3A0 907 379 E
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03704
Shop #: WSC 01157
2 Faults Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
35-10 - - - Intermittent
16-10 - Signal Outside Specifications - Intermittent
after swopping round the speed sensor connections under rear seats still got
after reading this and other forums i have come to the conclusion of ecu issues,
thanks for the input
regards
steve
