dino190 0 Posted April 21, 2009 Report Share Posted April 21, 2009 hello, i have an exhaust problem on my mark 2 vr6, it has a supersprint cat bypass pipe which has broken, it may be possible to weld it but i dont think it would last for long. The supersprint part is expensive, i am looking for options. there is a dutch company on ebay, hottuning, doing a replacement for about 55quid, but i'm not sure it has the bit for screwing in the lambda probe, there is also a milltek item at about 70quid. Anyone got experience of these? Or is there another option. thanks. Link to post Share on other sites
gavinvr6 0 Posted April 21, 2009 Report Share Posted April 21, 2009 there are usually one or 2 de-cat pipes knocking around on here, the hottuning products seem to be ok, obviously u only get what u pay for but for a stop-gap till u can afford or justify paying supersprint prices they are perfectly acceptable. i beleive they do have the lambda socket, if not its pretty easy ti just drill a hole and weld a nut on. Link to post Share on other sites
dino190 0 Posted April 21, 2009 Author Report Share Posted April 21, 2009 gotya, thankyou Link to post Share on other sites
GlasgowRob 0 Posted April 21, 2009 Report Share Posted April 21, 2009 can vouch for the milltekspot nn fit and no niggles Link to post Share on other sites
markiev6 1 Posted August 8, 2009 Report Share Posted August 8, 2009 if its a mk2 why have a cat ? not needed for m.o.t. just take it out Link to post Share on other sites
8vgtimk2 0 Posted August 9, 2009 Report Share Posted August 9, 2009 I have got a six branch header going which replaces the original header and cat... can I still fit the lambda sensor to keep and eye on the engine? Link to post Share on other sites
finny 0 Posted August 10, 2009 Report Share Posted August 10, 2009 if its a mk2 why have a cat ? not needed for m.o.t. just take it out Correct for not needing the cat (unless reg as a K reg) but you still need the lambda sensors fitted to a cat-by pass pipe or the engine will run crap. Often poor running is beacuse the lambda sensors are knackered (& require replacing) so if these are not fitted............ Link to post Share on other sites
