i guess you mean removing the dizzy completely ? if so then no but it will be a mega pain as they corrode in spray WD40 around it and let it settle for a bit but you may need some large grips to turn it side to side to free it up. but dont forget to mark it so you can put it back were it came off..
that is if your taking it out..
pete
oh ok, i actually wanted to change my rotor arm too but i cant see how it comes off, looking at the new 1 it just pushes on but ive tried pulling it off to no avail, im pretty sure my cam sensor is fine so i'll just leave the dizzy for now unless i have to take it off to get the rotor arm off... does the rotor arm come off easy? i just dont want to break anything!
Oh and thanks pete, that was what i meant!
