PEDROX 0 Posted February 8, 2009 Report Share Posted February 8, 2009 I thought you could get an adaptor to convert an obd2 inlet manifold to run an obd1 throttle body.cant find it. anybody know where to aquire onecheers Pete Link to post Share on other sites
CorradoVR6-n.o.s 0 Posted February 8, 2009 Report Share Posted February 8, 2009 probably need a custom one,plus you would need a vacum port for the idle valve if your using this? Link to post Share on other sites
craggsy 91 Posted February 8, 2009 Report Share Posted February 8, 2009 You can buy OBD1 to OBD2 adaptors....im sure stealth sell em Link to post Share on other sites
thegoth 5 Posted February 8, 2009 Report Share Posted February 8, 2009 You can buy OBD1 to OBD2 adaptors....im sure stealth sell embut aren't they OBD2 TB to OBD1 manifold, ie schrick? Link to post Share on other sites
craggsy 91 Posted February 8, 2009 Report Share Posted February 8, 2009 Yep for the schrick Link to post Share on other sites
thegoth 5 Posted February 8, 2009 Report Share Posted February 8, 2009 Yep for the schrickPedrox is after the other way around, I guess for some bling Link to post Share on other sites
craggsy 91 Posted February 8, 2009 Report Share Posted February 8, 2009 I was just saying I know of the other way round...just not that way Link to post Share on other sites
PEDROX 0 Posted February 8, 2009 Author Report Share Posted February 8, 2009 confused................so stealth sell obd2 to obd1 adaptors? yes? as per schrick inlets?? Link to post Share on other sites
craggsy 91 Posted February 8, 2009 Report Share Posted February 8, 2009 No...they sell adapters to change OBD1 schricks to OBD2. Link to post Share on other sites
gavinvr6 0 Posted February 9, 2009 Report Share Posted February 9, 2009 use the stealth one and mount it backwards? Link to post Share on other sites
PEDROX 0 Posted February 9, 2009 Author Report Share Posted February 9, 2009 thought about that, but not having seen one I dont know?do the holes go all the way through? does anyone know or have a pic?Cheers Link to post Share on other sites
CorradoVR6-n.o.s 0 Posted February 9, 2009 Report Share Posted February 9, 2009 you cant use it the other way as the adapters are contersunk for the bolts to fit the obd2 throttle bodysay you can fit OBD1 throttle body to OBD2 inlet manifold.....how are you going to make it idle?Why are you doing this swap? Link to post Share on other sites
