Is thiis anygood in a VR6 engine? just wondering if worth changing or just using the usual 92 unleaded?
cheers!
Where are you buying your petrol? Aldi?? 92RON that's like 2 star in the old money. UK unleaded is usually 96RON. This will be absolutily fine for your VR. Some people use ultimate / optimax religoiusly though for the 'better cleaning' and i must admit to the odd tank full of Tesco 99RON before rolling roads / 1/4miles
I run ALL my cars on Shell Fuel...Had problems in the past with different fuels...
VR and the race bus (when running on the road) run on Vpower, all the rest on normal 95 petrol or diesel
Some of the cars i have owned you can really tell the difference with the MPG and performance depending on the fuel
at the prices at the moment try running tesco 99ron, all the time you can get it for less than a quid its well worth it. standard 95ron is perfectly fine for a vr6. using higher octane fuel on standard/lightly modded engines dont really give any gains, but does burn cleaner so is better, but for the forced boys id say 99 ron all the way, they will benefit from the extra points
