Russvrt 85 Posted January 11, 2009 Report Share Posted January 11, 2009 hi my mk3 vr 95 obd2 has started loosing a little water i cant see any leeks and there is no water in the oil and doesnt overheat or feel like its lost any power??it has the black expantion cap and hear these can be troublesom ??any ideas thanks russ., Link to post Share on other sites
binliner 0 Posted January 11, 2009 Report Share Posted January 11, 2009 It could also be the water pump (mine went recently) check under that side of the car and feel inside the plastic cover that protects the lower part of the belt, coolant drips and catches in there Link to post Share on other sites
MAHOSTRIDERDG 0 Posted January 12, 2009 Report Share Posted January 12, 2009 I know this sounds stupid but have a real good look at your rad..my VR6 was losing water and i couldnt find a leak anywhere....After days of looking I found a small stone dent in the rad up behind a bumper plastic..(how a stone buried itself in there i dont know)....I only found it by spotting a drop or 2 of coolant in a dry under ground car park after da cinema one nite recently... Link to post Share on other sites
Russvrt 85 Posted January 12, 2009 Author Report Share Posted January 12, 2009 cheers i keep looking but cant see anything but doesnt help when it raind all night and day!! Link to post Share on other sites
Timah89 1 Posted January 13, 2009 Report Share Posted January 13, 2009 Had same problem too and fixed with Wynns equivalent of Radweld - worked fine then water pump failed [bearings shot and no vanes] When fitted new one better flow blew rad so had to fit new one from GSF - 2hrs work. Now perfect. Also thermo housing is prone to cracking. You can usually tell where leak is coming from as dried antifreeze leaves tell tale white splashes Link to post Share on other sites
