t111bul 0 Posted January 5, 2009 Report Share Posted January 5, 2009 Hi Guys,I have finally got my engine to run and it did soud like a spitfire before i attached the exhaust,it was awesome. But now i have the problem that when i start the car the engine will only run for a couple of seconds. I don't have my vacuum pipe connected but i wouldn't of thought taht would make any difference and when the engine is running the N80 vale clicks as thats not connected either. What should the N80 valve be connected to?It only has a pipe cming out of it that has been cut. Also my MAF looks to have seen better days as the mesh is torn on one side.Tim Link to post Share on other sites
cabrioman 6 Posted January 5, 2009 Report Share Posted January 5, 2009 are all the pipes on the intake main ... or could be imoblizer mate !! Link to post Share on other sites
t111bul 0 Posted January 5, 2009 Author Report Share Posted January 5, 2009 The imobiliser was removed this morning as it was pissing me off!yes all the pipe are on the main intake. Link to post Share on other sites
cabrioman 6 Posted January 5, 2009 Report Share Posted January 5, 2009 hmmm try gettin it on a vag com mate see if u got any codes Link to post Share on other sites
thegoth 5 Posted January 5, 2009 Report Share Posted January 5, 2009 The imobiliser was removed this morning as it was pissing me off!yes all the pipe are on the main intake.later engines have another immobilser built into the ECU. What year was the doner car? Link to post Share on other sites
t111bul 0 Posted January 5, 2009 Author Report Share Posted January 5, 2009 The donor car was a 1993 K reg,it is a coil pack engine if that helps? Link to post Share on other sites
UnitedMotorsport 55 Posted January 5, 2009 Report Share Posted January 5, 2009 Check the ECU number. From what your saying it should be 021 906 258AF. These ECUS have no in built immobiizers.The N80 valve is what controls the ammount of evaporative emmissions back into the inlet manifold, It should connect to a rubber pipe to the left of the throttle body on the inlet manifold as you look from the front of the car. Link to post Share on other sites
richievr 1 Posted January 5, 2009 Report Share Posted January 5, 2009 too early for a factory immobiliser then.. they came in halfway through 95, so it won't be that.i take it the engine, loom and ecu all came from the same car? Link to post Share on other sites
t111bul 0 Posted January 6, 2009 Author Report Share Posted January 6, 2009 What is the other end of the N80 valve attached to? Link to post Share on other sites
t111bul 0 Posted January 6, 2009 Author Report Share Posted January 6, 2009 Yes all the engine, loom and ecu came from the same car.I'm not sure of the ecu number as i work in France so i won't be able to work on the car for the next two weeks but the ecu has a non soldered chip. Link to post Share on other sites
