The Monk 50 Posted December 9, 2008 Report Share Posted December 9, 2008 When I'm driving, either on or off the throttle, there is a loudish humm coming from the engine bay. It isn't the fans.I've tightened up the manifold but it's still there, I've lost a slight amount of water but I'm not getting white or blue smoke from the exhaust even when I thrape it. So I don't think the head gasket is faulty.Anybody have any clues?Cheers in advance guys n gals. Link to post Share on other sites
spindat45 0 Posted December 10, 2008 Report Share Posted December 10, 2008 If you can't hear it on idle or at high revs when stationary then it could possibly be a wheel bearing. If the humming gets faster/louder with an increase in speed then that would point to the same thing. A bit hard to pin point which one if it is a wheel bearing. If there is a garage locally with 2 post lift, see if they'll let you get it on there and have a listen underneath.Kevin Link to post Share on other sites
gavinvr6 0 Posted December 10, 2008 Report Share Posted December 10, 2008 if its doing it whilst stationary and it increases and decreases with revs check the belt tensioner pulley. mine started as a humming noise then graduated to a scraping noise as the pulley bearings went dry Link to post Share on other sites
The Monk 50 Posted December 10, 2008 Author Report Share Posted December 10, 2008 Cheers chaps, will take a look. Have had experience with taper wheel bearings and normal bearings too, so I know it isn't that and I have checked.I'll have a check of the pully tomorrow.Cheers. Link to post Share on other sites
craggsy 91 Posted December 10, 2008 Report Share Posted December 10, 2008 Just maybe the engine doesn't know the words....or is just really happy in its work :-p Link to post Share on other sites
The Monk 50 Posted December 11, 2008 Author Report Share Posted December 11, 2008 Yes, it is the pully, going a bit dry and the aux water pump is on its way out. Link to post Share on other sites
