95 VR6 misfire, cracked coilpack
My 95 VR6 started misfiring yesterday.
VAG-COM didn't show me any faults.
I removed the coilpack and took these pictures.
There's three cracks in the plastic, could this be causing my misfire ?
If I have to replace the coilpack, is gsf a good place to get it from ?
Cheers for any help you can give.
It didn't fix the issue :(
I'm consoling myself with the fact that the old one was cracked and it's probably only a good thing that it was replaced.
Next stop' date=' plugs...
tbh it was probably best to try plugs 1st seeing as they cost a fraction of the coil pack....
have u tested to see which cylinders arent sparking then swapped the leads to try and isolate the cause of the problem??
Ahh, hindsight.
A set of plugs is £60 from gsf and the coilpack was £140
I took each lead off the coilpack while it was running and it changed every time.
Each lead sparked as I put it back on.
That made me think it wasn't one individual plug or lead.
Then when I took off the coilpack and it was cracked, I made that assumption.
Heyho.
I've held off getting plugs until the weekend while I have a read around and see what other possibilities there are.
what i would do is get a couple of crocodile clips and bolt them together, attach one end to a solid metal part of the engine to get a good earth... remove one spark plug and hold it with other end of the croc-clips around the threads... plug it into the HT lead and see whether theres a strong spark...
repeat for each plug, if one or two arent spraking go from there, if not then its probably a fueling issue
gl
hello. i had the same problem with my vr, i changed coilpack, new spark plugs and new plug cables. same problem after, i took compresion test on all sylinders and at was good,, I need to change ecu on my vr, it wont give the signals to 2 injectors so it just running on 4 cylinders, sounds like the same problem to me but.
I have a bad misfire, bought a coilpack from Trade Parts Specialists in Burgess Hill, Sussex, cost £142.89 inc. VAT. My car is a 1997 so ODB2 and the VW part number is 021905106 - it is described as 'IGNITION TRANSFORMER'. Not fitted yet, will tomorrow. Changed the plug leads today (and a couple where arcing - checked in the dark and could see it) but this has not unfortunately fixed the problem. Hoping the coilpack will sort it.
Got a new coilpack - proper job VW as the non OE one had gone wrong - for £142 inc. VAT. VAG have set up a number of 'parts only' dealers who sell proper VW OE parts to the trade at good prices. They will deal with the retail punter. That is where I got mine. Find yor local one, they are good.
