fitting a low comp spacer
please can any one give me any advice on fitting a spacer iv got a few thing im not 100% sure on and i wana fit it asap
1 are the torque setting different from the standard settings
2is there a special spray or anything i have to put on the gaskets before fitting
3 will i have to skim the head or will il be ok just cleaned
What head bolts/studs are you using?
You can use Permatex copper spray between surfaces.
So long as the head and deck are clean and flat nothing will need skimming. Give both faces a light sanding with some 180 grit or similar. Dont forget to put the two dowels back in!!
thanks mate ill try and get some of that spray can you get it from any shops or will i need o order some i havent ordered any bolts or studs yet was just going to go to gsf but am i better off getting arp ones or similar
Just a quick hijack of this post, but it is kinda relevant. As my head is coming off soon and I am going FI in the near future. If I fit a LC spacer gasket when the head comes off will there be an unbearable change in performance while I w8 to complete my FI project ?
Good stuff that permatex.
With regard to skimming, the only issue I've seen from NOT skimming an otherwise good looking head is an oil seep from Cyl 1 end of the block.
Doesn't happen every time though. The skimmed engines tend to seal better from my experience.
On the ARPs, retorque them after 500 miles. I find a couple of nuts tend to come loose, but again, not all the time.
what about if you dont have the mk4 gasket, but still have a spacer plate can you just stack the gaskets ?? as in i have a o/e gasket and a spacer gasket, i was planning on stackin them like people used to do on rs tubos and such.
