Seem to have lost some Torque :-(
At TSR yesterday Absy returned 197bhp and 169lbs/ft torque. The bhp wasn't bad but was hoping for 200+ however the Torque figure is dissapointing. So the BIG question is where has the torque gone ? Previously the torque was 189lbs/ft.
I believe the equation to work out horsepower is (Torque x RPMs) / 5252, therefore a slight increase in Torque would bump the bhp up considerably.
A while back i did a compression test and the figures were slightly down on previous, could this be causing an issue. I always had concerns about the valve guides, perhaps the valves aren't seating properly.
Absy is driving superbly at the moment (touch wood) and i'm really chuffed or obsessed (fine line).
So come on you guys ........ can anyone shed any light on were i could regain my torque especially as this is the most important figure ;-)
Did you have it rolling roaded at the same place both times?
yeah it was, the only other RR was at Stealth when it wass mapped and torque was nearly 190 then with 203bhp
only thing i've done is clean out BMC, fit neuspeed pulleys, bosch plugs and use Vmax
seems to be going brilliantly, always struggling with traction if i boot it
'm really confused and and a little concerned
Could it just be wrong plugs and mine hates Vmax
When was your last service?
its well looked after
Didn't mean to insinuate it wasn't looked after, but it's usually simple things that people overlook that make all the difference, Personally i'd ditch the bosch plugs. Never had nothing but issues with Bosch and Champion plugs over the years with various motors, i'm NGK every time.
BTW I notice you're slightly down on compression, have a cylinder leakage test done, that'll tell you exactly where you're losing out.
All the VR6s I've been in' date=' naturally aspirated and forced fed have loved V Power, so something doesn't sound right! Hope you solve it.
Cheers Kev, its in bodyshop having a couple of bits touched up dint get chance to run Vagcom, will do it when it comes back
Ran VagCom and nothing ..... I'm gonna right this off as a bad run, the car is running soo sweet. Just seems too weird I can't compute.
Tyres and Clutch are going thro my head at mo .....
All ears tho if anybodies got any ideas :-)
