ZR2 Charger & US Software?
If the charger is an American zr2, I'd leave it alone as none of them have the cogged drive belt because it infringed a US patent by another manufacturer using a cogged setup. Some are ok as they have been sent back to the factory for upgrading with the cogged pulleys. Just avoid the ones with ribbed belts as they will have belt slippage issues.
Giac is ok but it will be mapped for American fuel so potentially it will underperform.
If the charger is an American zr2' date=' I'd leave it alone as none of them have the cogged drive belt because it infringed a US patent by another manufacturer using a cogged setup. Some are ok as they have been sent back to the factory for upgrading with the cogged pulleys. Just avoid the ones with ribbed belts as they will have belt slippage issues.
Giac is ok but it will be mapped for American fuel so potentially it will underperform.[/quote']
It got sent back to Switzerland for the upgrade so it should be fine i suppose. Thanks for the info Ben.
