any help please,apex or bilstein springs???need to know asap please!!!!!!!
hi all,well i went to euro car parts today to get me some springs,the guy said that the bilstein springs were good so i opted for them ,juat checked the box in my boot and it turns out hes given me apex instead ,are theese shite? or better than bilstein ?
if theese are poop i will take back in morn so help needed please as my mans coming round tomorrow to fit them
cheers wookie,do you know if bilstein are better for a vr6 tho, as they are what the fella in euro car parts recomended and then i end up with apex?
has messed up my mind a little :S
i can get them back to him early in morn but real early as football is on at wembly stadium {next door to euro's} and its gonna be a no go zone for cars ,
thanks for all your rapid help,i ended up just replacing the two front with new originals as they needed doing ,im gonna take back the apex's tomorrow as when my m8y come round to fit them he said as i now have 17ins wheels if i use the apexs i will probly get rubbing in the arches,
got to say just by changing to two new original fronts has helped bundles with the handling would recomend to anyone with original springs.
also glad my pal pointed out that my fuel filter was about a 100 years old {factory fit with clips you have to cut} so been on there since it left the showroom so fitted new one straight away
well full speed ahead now .........for now
i cant be sure of an actual check you can do but somone might,but ive always believed its good to change it every 10k or 20k as its a filter and if it does its job filtering crap out of fuel then its gonna be filled up with that crap so its worth a change especially as mine was the one that came with the car from new and now it has neary 80k on the clock,
god knows if the owners before me drove round on the red of the fuel gage and kept pulling crap up from the bottom of the petrol tank.
well worth a change for £8 and and a couple of jubilee clips :)
drivers side under car just before back wheel ,have a look, looks like a can ,you can probly feel it if you run your hand along underneath
,engine off ,
on the filter you will see a pipe going in and a pipe going out ,use somthing to squeeze both the pipes just before they go onto filter,this stops fuel shooting out when yo take the pipes off ,
next take off the pipes and make sure you know what way the pipes go there is an arrow picture on the old filter so when you put the new one on you put the tubes the same way with regards to the arrow ,
sorted!
im sure if you search this site there is a much better post on how to do it than i have wrote,
dont take no more than 10mins (e)
