i did the same i fitted em then counted the threads as i didnt have a tapemesure to hand lol' date=' but the hardest bit is setting the camber angle asif you golf is low like mine then there is hardly any room to get in and adjust em,
any info on the camber bit please cos i did not know about that
cheers
Never in a million years will you get it accurate (camber angle) you may get it within half a degree, do it roughly your self drive it for a couple of days then get it 4-wheel aligned. Even with the right tools it took my man about 25 mins to get it right.........................anything other than perfect and the handling will do very strange things..............i put mine about half way (height on the thread) and it was about a 70mm drop............ :-p
It's like plastering lol you can mess about for hours and never get it right but pay a man with the right tools and skills and it's done and you'll notice the difference immediately
You've invested in making the car look better. spend a little more, get it 4 wheel aligned and it'll but a big smile on your face
camber is a pain to set as every time you ajust it you need to reajust the tracking,i have set mine to 1.6 negative to improve turn in on track but this is fine for road use (you also need to check camber and tracking if you change ride hight)i have set my car up to be perfect when i sit in it(it goes out by 0.1 of a degree without me in it)
it took me 6 goes to get it right (prob why most places dont like doing it)
