Lukey 0 Posted January 21, 2004 Report Share Posted January 21, 2004 Hi everybody, this i my first post, so I hope that it makes sense...I have a '95 HIGHLINE VR6 and love it but fancy a bit more. I have changed the exhaust and have a K&N cone filter on at the moment but wondered what people's experience was of chipping and fitting gas flowed throttle bodies etc.An advice would be greatly appreciated and thanks for all the other posts too, they have been a great help already.PS. Does anyone have a VAG COM link. If so, are they any good ?Thanks Link to post Share on other sites
nickbee 1 Posted January 21, 2004 Report Share Posted January 21, 2004 If you have an early VR6 like mine, the throttle body and chip make a big difference - you'd about 190bhp when coupled with a K&N. Late VR6s (including Highlines like yours) had a higher output than early ones - they produce 185ish anyway. They've got different engine management and a slightly different throttle body (I believe it's the same size, but electronically controlled). In short, VW has already chipped them and uprated the TB so there's no point in you doing it.If you've got £500 burning a hole in your pocket and haven't done your suspension yet, do that. For more speed, you'll need to think about cams (even better top end, even worse low end), a VSR manifold (brilliant, but £1500) or forced induction (£2000+).Jules (jcorallo) has a VAG-COM. They're handy if you've got problems. Link to post Share on other sites
Lukey 0 Posted January 21, 2004 Author Report Share Posted January 21, 2004 Thanks for the quick reply. I have already changed the suspension which was definitely money well spent as it is now a much firmer ride. So it doesn't look like there is much to be gained from changing then chip or TB.....If I were to go for cams, do you know if it is a big job to do ?I guess that one of the main things that I wanted to improve was the power at low revs as it doesn't seem to really go until about 3.5-4k.I have also heard a few people talk about cleaning the TB. Is it worthwhile having a look ? If so, is it easy to get to ?Many thanks Link to post Share on other sites
Gwalkvr6 0 Posted January 21, 2004 Report Share Posted January 21, 2004 Save up your money and buy a VSR!!!!!Worth the money and will make the most difference to the car across the rev range but especially low down. Link to post Share on other sites
nickbee 1 Posted January 21, 2004 Report Share Posted January 21, 2004 If you want power at low revs, cams aren't the way forward, if anything they make low-end power worse. Not an easy job to fit either. The only real answer to your problem is a VSR manifold.The throttle body's not hard to fit, it's at the rear of your engine, and held on by a couple of clips and about four bolts. Link to post Share on other sites
Lukey 0 Posted January 21, 2004 Author Report Share Posted January 21, 2004 Thanks for all your help. It looks like the VSR is the way to go then !I've had a quick look around but I presume that second hand ones rarely come up for sale...Can anyone recommend the best place to get one. I am based in Kent and may have to start saving !!Thanks again... Link to post Share on other sites
binliner 0 Posted January 21, 2004 Report Share Posted January 21, 2004 Id recommend Stealth Racing or AmD.They do come up second hand for about £750-£1000 (try PVW classifieds) but you'll have to spend about £300 to get it remapped plus fitting unless you do it yourself. Link to post Share on other sites
nickbee 1 Posted January 21, 2004 Report Share Posted January 21, 2004 Very rare, and when they do they're sold straight away. There was one in PVW classifieds a while back for £800 but it was sold almost straight away.AmD in Oxfordshire do them, including fitting and remap (you need one with a VSR) for £1500 +VAT. Link to post Share on other sites
binliner 0 Posted January 21, 2004 Report Share Posted January 21, 2004 LOL... great minds! Link to post Share on other sites
nickbee 1 Posted January 21, 2004 Report Share Posted January 21, 2004 Oh, so someone else is awake this morning! Good advice there, couldn't have said it better myself. Link to post Share on other sites
Lukey 0 Posted January 21, 2004 Author Report Share Posted January 21, 2004 Thanks for the excellent advice guys. Looks like I will have to start saving for some more power !Cheers Link to post Share on other sites
