gav_113 0 Posted July 3, 2007 Report Share Posted July 3, 2007 hey peeps, right ive had a prob with my car pressurising the header tank for ages now, well since ive had the car!ive never got to the bottom of it, well today i took the thermostat out and had a look.....and found that some one has drilled two holes in it?? well i put a new one in and now it boils up straight away, all the pipes are rock solid.. so i got pissed off and took the head off.i think the head gasket has gone on one cylinder, also i noticed that bits of my old water pump were wedged in the water ways in the gasket!!so i thought well ill just change the gasket and skim the head , until i seen the chain guides. the front one is snapped in two, and the back one is wafer thin!! i can replace the front one, but cant see how to change the back one??what i need to know is....Do i have to remove the gearbox to remove the bottom chain cover???and to top it off i snapped the back engine mount on the way home!!!!all in all not a gd day... Link to post Share on other sites
craggsy 91 Posted July 3, 2007 Report Share Posted July 3, 2007 Gearbox off i'm affraid for lower chain Link to post Share on other sites
gav_113 0 Posted July 3, 2007 Author Report Share Posted July 3, 2007 its the top chain guide,, but now im thinking if the tops are fucked the bottom chain guides maybe to?? is it ok to just replace all the guides and not the chain? its only got to last till my 2.9 engine has been built?? Link to post Share on other sites
gav_113 0 Posted July 3, 2007 Author Report Share Posted July 3, 2007 pics!!!!!!![lightbox=../../e107_files/public/1183502633_2891_FT182646_bild0368.jpg][/lightbox]do i have to remove box to change this guide??[lightbox=../../e107_files/public/1183502633_2891_FT182646_bild0369.jpg][/lightbox][lightbox=../../e107_files/public/1183502633_2891_FT182646_bild0370.jpg][/lightbox] Link to post Share on other sites
matth76 1 Posted July 3, 2007 Report Share Posted July 3, 2007 No. Although rare, chains can and will snap... meaning end of engine. Just replacing the tensioners is definitely no good. A member on here had their chains snap recently...not good! Gearbox out job unfortunately mate. Link to post Share on other sites
gav_113 0 Posted July 3, 2007 Author Report Share Posted July 3, 2007 what kind of money we talking for chains and guides etc.......?? Link to post Share on other sites
crish72 0 Posted July 4, 2007 Report Share Posted July 4, 2007 Have a search around for "timing chains" - it's been covered thousands of times!But as a guide, mine are getting done right now, all the parts needed cost £198 from VW and my mechanic reckons around £250 labour, probably having a new clutch also whilst the box is off..Chris Link to post Share on other sites
budgie 0 Posted July 5, 2007 Report Share Posted July 5, 2007 dude i just priced up these bits from vw and chains x2 were £80 and tensioners x2 were £55. for genuine parts, you could buy cheaper but gsf said they can only get tensioners and not the chains. Link to post Share on other sites
gav_113 0 Posted July 5, 2007 Author Report Share Posted July 5, 2007 has anyone ever done just the guides and tensioners and not the chains......im skint..or is it not worth the risk....advice pls.. Link to post Share on other sites
matth76 1 Posted July 5, 2007 Report Share Posted July 5, 2007 Not worth the risk mate - Anyway not sure if you can do the bottom tensioner without taking the gearbox out anyway (someone will confirm this) so the chains may as well be done too, and clutch. Mainly for peace of mind but if the chains do need doing in the future you don't want the hassle of having to take the gearbox out all over again. Link to post Share on other sites
philbatesvr6 0 Posted July 6, 2007 Report Share Posted July 6, 2007 yea you have to remove the box to do the lower guide thats why its common practice to replace the clutch as well, i got quoted £400 ish to do the chains guides and clutch from PSI in stoke Link to post Share on other sites
gav_113 0 Posted July 9, 2007 Author Report Share Posted July 9, 2007 right tonite i fitted new chains and guides, timed it all up, and bolted flywheel, clutch and box bk on, just waiting head to come bk from machine shop... one thing tho is i cant see any timing marks on the crank pulley??? Link to post Share on other sites
gav_113 0 Posted July 13, 2007 Author Report Share Posted July 13, 2007 tonite i finished putting my car bk together...started first time aswell, well chuffed, and saved my self £££'sin the end i changed the followingrear engine mountchains and guides/tensionersmk4 3 layer head gasket and boltsrebuilt obd2 head/plastic rocker coverive painted my inlet manifold aswell, coz it was so dirty, and didnt have time to polish it..lolpost sum pics 2moz.. tbh honest it wasnt as bad job as i thought... enjoyed it aswell.. Link to post Share on other sites
EmkayVR6 0 Posted July 17, 2007 Report Share Posted July 17, 2007 Sweet Good work, i gotta do mine very soon as well as a bottom end rebuild Link to post Share on other sites
gav_113 0 Posted July 21, 2007 Author Report Share Posted July 21, 2007 engine back in, running sweet!![lightbox=../../e107_files/public/1185036972_2891_FT182646_bild0410.jpg][/lightbox][lightbox=../../e107_files/public/1185036972_2891_FT182646_bild0407.jpg][/lightbox] Link to post Share on other sites
SiGainey 1 Posted July 21, 2007 Report Share Posted July 21, 2007 Good job - respect for doing it Link to post Share on other sites
